OBC fuel range?????
koos
Post Thu Jun 30, 2005 10:03 am
good day to all, i have a 1991 320iSE. Everything works on the OBC, except when I check the range of the fuel? When the fuel light is on ie:zero fuel, it gives me a range of 300km? unless it can run on a sniff of fuel, unlikely, then there is a prob. how does it get its reading? Any help would be great!!!
Koos
Post Thu Jun 30, 2005 2:15 pm
Never tried it, but ther's an adjustment under a little blanking plug in the lower left corner, IIRC.
Cloggy Saint
Post Thu Jun 30, 2005 4:38 pm
To get a remaining fuel reading, press the 1000 & 10 buttons simultaneously. Fill the car up, and then turn the screw behind the bung at the bottom left corner until the display reads your tank capacity.
koos
Post Fri Jul 01, 2005 9:51 pm
thanks for the help, tried it out but it didnt work. pushed lots of buttons and it worked. It's the 1000 & 1 buttons, you can only change it about 2L max.thanks
