3.5 conversion question
Driftben
Post Wed Dec 03, 2008 8:27 pm
Hi all
i have been offered a 3.5 with no ancillaries or gearbox. i was wondering what would be needed for doing a swap from a 2.0? what gearboxes would be best for it?
thanks
Ben
MJJ_ZX6RR
Post Wed Dec 03, 2008 9:20 pm
There's a 5 page thread in this 'Engine Swaps' forum all about the swap. Cannot remember the title exactly, but it was replied to recently and definately has M30 (the BMW code for the 3.5) in the title.
I'd start there.
I have a 335i conversion myself, from the little experience I've had so far (not MOT'd yet), I'd say definately go for it. Gut feel is that the without ancilliaries and gearbox, you may be looking at a lot of searching and delays in the conversion. May well be better to buy a complete car as a donor.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
Driftben
Post Wed Dec 03, 2008 9:36 pm
ah i see well i have emailed the bloke and he has all the stuff to complete the engine. so that helps alot.
he also has a manual box too.
what sort of price should i offer him for the whole lot?
is the M30 box ok to fit into the E30?
thanks
Ben
Post Wed Dec 03, 2008 9:45 pm
M30 box will fit straight in, all you have to swap is the m20 box mounting bracket,easy, and also change your selector rod for a 325 one to get the g/lever in the correct position inside the car.
I did most of mine myself, so any other question you have i should have the answers.
You can also use the m20 wiring loom with some mods.
:cool: HTH
Driftben
Post Wed Dec 03, 2008 10:16 pm
ah lovely stuff, great info.
well ill be starting the conversion once i pick the M30 up. wouldnt mind to replace bearings ect while its out? what do you think?
also i am supercharging it too so i would mine renewing some things
thanks
ben
Post Wed Dec 03, 2008 11:55 pm
Good one on the forced induction, as i was going down that route too, but maybe in the summer. :cool:
fowler
Boost Junkie
Post Thu Dec 04, 2008 5:34 am
i would personally put in a M50 b25 better engine and weighs alot less than A M30 engine
EX A-Tech Workshop bitch !!!
gone but not forgotten
Driftben
Post Thu Dec 04, 2008 10:11 am
fowler wrote:i would personally put in a M50 b25 better engine and weighs alot less than A M30 engine
I see where your coming from on that one. I'm going to sit the engine as far back as I can and look for weight saving options. But as they say no replacement for displacment.
Ben
zaust
Zone day release
Post Thu Dec 04, 2008 10:19 am
There is acctually more room on mine to work on the motor and round the gear box with the m30 than with the m20..
M30 Tech 1 Touring on gas.
Theo
Post Thu Dec 04, 2008 10:23 am
Have you actually weighed them? All the figures i've seen state very similar weights for the two engines.
The great advantage of the M50 is fuel consumptions, which should be better. But a big six powered E30 is so much more fun to drive.
zaust
Zone day release
Post Thu Dec 04, 2008 10:32 am
Agreed.. Why swap a 2.5 for a 2.5.
Post Thu Dec 04, 2008 2:23 pm
Here Here :cool:
Ziggy
Post Thu Dec 04, 2008 2:30 pm
Because they're a more powerful, more economical engine. Not directly comparable to an m30 swap though IMO - your choice would depend on what you wanted from the car.
Driftben
Post Thu Dec 04, 2008 7:14 pm
well i want the engine looking kind of the same apart from a shinny supercharger hanging off it somewhere. plus cant beat the sound of a straight six. not really too bothered on the eco sides of it as its not a daily driver. plus green peace can kiss my ring. :mad:
iv managed to get the whole engine plus box for £700 which i didnt think was too bad.
Ziggy
Post Thu Dec 04, 2008 7:18 pm
STiBen wrote: iv managed to get the whole engine plus box for £700 which i didnt think was too bad.
That's waaay expensive.
Driftben
Post Thu Dec 04, 2008 7:22 pm
really? pants, what sort of price should i be looking for?
Ziggy
Post Thu Dec 04, 2008 7:27 pm
£200ish, more like... An example'd be ebay item number: 320322611051 (didn't sell previously @ £150 start / £225 BIN)
You'll be able to pick up a whole car for sub £500, easily.
Driftben
Post Thu Dec 04, 2008 7:32 pm
hmmm sounds good
well i have found a engine for £250 and a gearbox for £145
what do you think of them prices?
might pop on to the wanted forum.
Ziggy
Post Thu Dec 04, 2008 7:33 pm
Again, that ebay advertiser would take £200 for the both, but £400 is obviously better than £700!
Theo
Sounds reasonable, make sure you get the loom, ecu, starter, alternator, PAS pump, exhaust manifolds and downpipes with the engine.
Driftben
Post Thu Dec 04, 2008 7:47 pm
thing is im down in kent and thats a long way from me, plus iv only got a astra van lol. dont mind traveling but not too far.
why is everyone so far from the south :(
turkey
Post Sat Dec 06, 2008 7:59 am
just buy a donar is by fay the best way, you should be able to able a rough manual for aroun £300-400 just make sure the engines good!
OR
Pick up my M30 out the garage for free and spend the £400 fixing it up winkeye was a strong engine till the rocker arm snapped, all compression was spot on for each cylinder!
Driftben
Post Sat Dec 06, 2008 2:34 pm
well Free is a word which doesn't come round often winkeye
iv just PMed you but whats missing from the engine? ill be striping it down anyway so replacing the rocker arm wouldnt be too much of a problem.
ill be taking my M20 out sunday so ill have time to clean the bay up and alter the loom before the M30 goes in.
oh i love projects
turkey
Post Sat Dec 06, 2008 6:31 pm
theres no loom, starter or gearbox... It would make a good project, was thinking about playing with it and a turbo but just havent got the time and need the space,
If you do have it i want to see pictures of the build though! :cool:
Driftben
Post Sat Dec 06, 2008 8:00 pm
Well I will be doing all the fabrication myself so I'll put pictures up of each stage. Whats the chances of get it in the back of my astra van?
Ben
Post Sat Dec 06, 2008 8:10 pm
There is a manual box for the M30 on ebay at the moment
turkey
Post Sat Dec 06, 2008 9:56 pm
just pm'ed you back, as for the astra van it will fit in there no worries... as for using the engine crane to lift it in the back may be a bit tricky as there quite low roofs on them iirc!?!
Driftben
Post Sun Dec 07, 2008 10:11 am
well as far as im aware i have found a gearbox from a lad on here which he is sending for £65 delivered which i thought was reasonable.
as for putting the engine in the van, im sure if we take a long enough run up it would go in winkeye
looks like the transplant will be going along shortly.
turkey
Post Sun Dec 07, 2008 6:17 pm
lol i'm sure it will if you want it, shame about the missing parts for it.
Do love driving my M30, such a laugh... but you'll hate it when your working on it and things arn't going as they should...
Driftben
Post Sun Dec 07, 2008 6:33 pm
well parts wont be too much of a problem as i have abit of time to scout about looking and collecting.
when i pop up to see you ill have to cast a eye over your conversion you get abit of a idea.
already started disconnecting and unbolting the M20 today. just have to finish unbolting the drive shaft and abit more of the loom and its ready to come out.
iv put a skyline engine into a 200sx before so im preparing myself for bleeding knuckles and bruises.
turkey
Post Tue Dec 09, 2008 7:36 pm
lol, if you done a conversion before then this shouldn't be to bad for you, the hardest part is getting it into place, then the rest isn't too bad tbh. Feel free to look over mine, just don't knock my exhaust its just temporary!
Driftben
Post Tue Dec 09, 2008 9:15 pm
haha well as long as its not held together with the famous duck tape then thats fine for me.
ill be passing by essex on the way back from Milton kynes not this sat but next sat (the 20th i think) would it possible if i could pop by to cast a eye and pick the lump up then?
thanks
Ben
beefy
Post Tue Dec 09, 2008 10:12 pm
Ben if your needing some mounts i can supply them pm me for more info if required
E30 M30 Mounts £100 pm me for info.
Driftben
Post Wed Dec 10, 2008 7:39 am
Ah yes I was going to contact you for that. I have read the write up that was on them and it looks like I'll be getting yours instead of making my own. I think it will be after the new year I'll be wanting that. Get christmas out the way and all.
turkey
Post Wed Dec 10, 2008 6:09 pm
So that's the 20th, that should be fine but won't be home till about 4-5 is that ok?
I'm using the mounts of beefy and can recommend them, very well made and do the job fine!
