supercharging a 325
cruizin4dirty1s
Post Tue Dec 02, 2008 6:42 pm
just wonderin has anyone ever supercharged a 325 before and what would ya need
rix313
Post Tue Dec 02, 2008 7:03 pm
Super charger ;)
Lots of spondoolies help too.
Good contacts in the fabrication world to try keep the cost of custom work down.
A way of cooling the air from the charger.
Uprated injectors.
More than likely a pressure release valve (depending on set up).
New clutch if you want to make sure the new juicey power is laid down more efficiently.
Possibley uprated brakes to make sure you stop betterer.
New ECU and loom to match.
Off the top of my head.
ShakeyC
Post Tue Dec 02, 2008 9:45 pm
Already been done, developed and unleashed into the world
http://www.fastbimmer.co.uk/projects/pr ... otrex.html
Nay
Channel Island Crew
Channel Island Crew
Post Thu Dec 11, 2008 6:37 pm
ShakeyC wrote:Already been done, developed and unleashed into the world
:drool:
Uni is killing the project.
TomCropp
Post Sun Dec 21, 2008 6:57 pm
mmmm more spondoolies needed for that one me thinks :(
kingcruizer
Post Sun Dec 21, 2008 11:13 pm
that'll be my engine. loads of money but :cool: a-tech is what you need...
my sig pic says it all..
do it, you know you want to.
"BEFORE I DIE, I WANT TO OWN A CAR WITH AN ENGINE THAT STICKS OUT OF THE BONNET"
TomCropp
Post Mon Dec 22, 2008 8:02 am
has anyone fitted an eaton supercharger (cooper s) to a 325?? will it fit
Ant
Retired Team Member
Retired Team Member
Post Mon Dec 22, 2008 8:28 am
tom, its too small dude.
look @ it this way... BMW removed the stock units for the works cars, and even then they are limited boost into 1600cc engines.
M20B25 is a big air pump, to get more you need to add a bigger air pump, follow the logic ??
TomCropp
Post Mon Dec 29, 2008 8:27 am
Ant wrote:tom, its too small dude.
i get you dude... so really in an ideal world you need a rotrex ..
rix313
Post Mon Dec 29, 2008 11:10 am
Bingo :)
