Removal of M20 Crankshaft - How do i do it?
Quaser
Post Wed Jun 29, 2005 8:24 pm
Hi
Could anyone please tell me how to remove the crank.
I have taken off the pistons and all the 'things' holing the crank in. Un done the front bolts and the cover is loose, but cannot remove it due to the toothed timing pulley.
Please help!
Q
M5pilot
Post Wed Jun 29, 2005 8:54 pm
What are you upto now?
Not gettin the 2.7 rebuilt then?
Turbo-Brown
Boost Junkie
Post Wed Jun 29, 2005 9:16 pm
Aah, if you haven't taken the timing pulley off, you can't have taken the oil seal housing off either and this needs to be unbolted and knocked off it's dowels before you can lift the crank.
Adammcf
Post Wed Jun 29, 2005 9:55 pm
If you can still see this then you need to undo the little 6 bolts in the pulley and then gently tap it off with a hammer.
Then you'll see this:
Hope that helps.
Quaser
Post Wed Jun 29, 2005 10:40 pm
got it off thanks
i was whey past that point - took off flywheel and found bolts under there - all done now though!
Q
