Whats the difference between 320i and 325i
springh
New to the E30 stuff, just trying to work out- other than the CC difference what other differences are there between the 320i and the 325i? are things like the manifold different? I have a 320i and im trying to get the most out of the engine...
StuBeeDoo
Hi Springh, welcome to the 'Zone.
The 'head is different on the '25, as are the inlet manifold and the throttle body. To put it politely, the '25 head (881 casting) can be a bit fragile, shall we say. The 'heads are not interchangable, as the '25 uses different pistons.
Quite a few people (I'm not one of them - yet) have fitted '25 throttle bodies to '20's, with amazingly good results. There are two ways of doing this:
Modify the '20 manifold to take the '25 TB.
Or...........
Port the '20 'head so that the '25 manifold can be used.
If you take the first option, the job's easier and the mid-range power gains are better. The '25 manifold option sacrifices a bit of mid-range gain, but gives even better top-end.
If you use a modified chip too, the gains are even better.
HTH
Stuart.
Or...........
HTH
Stuart.
320Touring
differences are....
40bhp more in the 325
better noise from the 320 (smaller bores
Head design -320 is a 'flahead'=combustion chamber is horizontal at the top, 325 is 'hemi'= like half a sphere
the 325 also sometimes suffers from porous heads/cracked heads due to the fact that the water channels are closer to the chambers
StuBeeDoo
Karan
325 has rear discs... i dont think 320s have rear discs....
StuBeeDoo
Geeman
Unless it's a convertible, then they have rear discs...
StuBeeDoo
Chaos
2.5 has an oil cooler behind the bumper i dont think the 2.0 has that
Chaos
causing havoc and mayhem wherever i go
320Touring
nice one Chaos-always forget about that one....Chaos wrote:2.5 has an oil cooler behind the bumper i dont think the 2.0 has that
but was it not an optional extra????
Chaos
not sure m8, def standard on 2,5 but dunno if it was optional for the 2.0.320Touring wrote:nice one Chaos-always forget about that one....Chaos wrote:2.5 has an oil cooler behind the bumper i dont think the 2.0 has that
wud be a nice addition tho to a 2.0 i reckon.
help keep everything cool
Chaos
Simon
Not optional, standard on all 325i.320Touring wrote:nice one Chaos-always forget about that one....Chaos wrote:2.5 has an oil cooler behind the bumper i dont think the 2.0 has that
There was a thread on the old zone about fitting the coolers to the 2.0's, but it was deemed totally un-neccesary.
320Touring
thanks for clearing that up Simon!!!Simon wrote:Not optional, standard on all 325i.320Touring wrote:nice one Chaos-always forget about that one....Chaos wrote:2.5 has an oil cooler behind the bumper i dont think the 2.0 has that
and nice thinking Chaos
325's don't really need oil coolers. Mike Australia does not have one on his 325 cab and his don't over heat in 45 C!
dazleeds
- old skool raver
my h plate 320ise has rear discs as standardKaran wrote:325 has rear discs... i dont think 320s have rear discs....
www.oldskoolfantasy.co.uk
