I have two E30's, both D reg. one a 318 and the other a 325i. The 325i has beed accident damaged, so I want to transplant the engine and gearbox into the 318. Does anyone know how big a job this is, does the wiring loom have to be changed to accomadate the engine management for the 325i engine?
Best regards,
Roland.
Transplant 325i engine into 318 car
E30Adam
It's quite a big job all in the grand scheme of things. I wouldn't call it a difficult one but it depends on your knowledge.
You'll need:
Engine
Gearbox
Prop
Diff
Wiring Loom
ECU
Suspension
Rear Brakes if you want any chance of stopping
Instrument cluster coding plug
You'll need:
Engine
Gearbox
Prop
Diff
Wiring Loom
ECU
Suspension
rllewellin
Thanks for the info Adam.
I am looking for a car for the BMW RWD Rally Challenge.
I still need a 3.64 LSD for a 325.
Any one know where I can get hold of one?
Regards,
Roland
Regards,
Roland
I'd be more concerned about the front brakes than the rears. For a car to be used for rallying, the 318 rear drums could be an advantage. Much better for handbrake turns
