E30 M3 LSD
mgarrett29
Anyone know what the diff oil is for E30 M3 LSD? Everywhere I go says refer to manual, which I don't have.
Jos
Probably the same for all the BMW limited slip diffs.
Ask your dealer for it, they have oil for LSDs, probably Redline 75W-90 Gearoil.
Or you can use Castrol SAF-XLS which is designed for LSDs as-well.
Or you could ask the 'oilman'
http://www.e30zone.co.uk/modules.php?na ... opic&t=156
'94 e36 tree climber
boybimmerm3
the stuff you need to use is castrol xj.
Jos
Sorry yes, Castrol XJ is the stuff, XLS is the older stuff that XJ replaced
Sorry
Sorry
