bit of advice needed
jimbojetset
right guys i need a bit of advice what is the best back end and diff to use for a3.5 convertion . been told to use 325 back end and front end set up includind a standard 325 diff any body know athing else
snoops
- Major Helmet
I take it you mean a 325 rear brake setup? From what I have seen 3.46, 3.64 diffs are the best to use for a 3.5 conversion depending on what you want. Give rav320uk a shout, he has just converted his cab to a 3.5 and is using a 3.64 diff IIRC.
leeparkes
im sure rav is using a 3.46,
apparently its the best all round diff for the m30 conversion
