e30 325i fuel pump location external or in tank ?
jaistanley
It's in the tank... Under the rear seat on the drivers side (RHD cars that is) there is a plate. Remove this and you can see the pump and fuel level connectors.
I'm not sure about the diesels, they might have an electric lift pump to the high pressure fuel pump..
Jai
Jai
even petrol models can have dual pumps , 1 in tank is a low pressure (lift up) and the one outside side is the main high pressure pump , have a look under the car if you see a pump like this
then you got dual pump set up , if not then its got the single pump in the tank like this
sati wrote:even petrol models can have dual pumps , 1 in tank is a low pressure (lift up) and the one outside side is the main high pressure pump , have a look under the car if you see a pump like thisthen you got dual pump set up , if not then its got the single pump in the tank like this
you are right sir. car has external pump too
CG_Maintenance
early have external
late internal
i believe
late internal
i believe
Can I kill it, can I eat it, can I Fk it ?
Composite Doors, uPVC Repairs and Instalations.
- Brianmoooore
Change over from two pumps to one was shortly after the introduction of facelift cars - around the beginning of '88.
