oil leak
kylepiggy
Sun Nov 02, 2008 9:30 pm
my 320 has an oil leak under the oil filter have checked the oil filter and all is tight before i buy a new one just incase the seal has gone is there any other common places the m20 leaks thanks
leeparkes
Sun Nov 02, 2008 10:59 pm
unless its got an oil cooler (which i doubt) replace the filter
or clean around the area,run the engine and watch!
chumak
Mon Nov 03, 2008 2:41 pm
kylepiggy wrote:my 320 has an oil leak under the oil filter have checked the oil filter and all is tight before i buy a new one just incase the seal has gone is there any other common places the m20 leaks thanks
can be an oil pressure sensor
Mon Nov 03, 2008 6:32 pm
There are dozens of places a 320 commonly leaks oil from, including the oil pressure switch, but none of these are relevant if the leak is from the oil filter.
