wierd......................
TOFTY
Mon Oct 27, 2008 11:55 am
if i slam my glove box shut my ABS light comes on 8O
anybody any ideas???? its got me!
and you dont have to say it , i know dont slam it!
Jon_Bmw
Dangerous when thinking
Mon Oct 27, 2008 11:57 am
The ABS control unit is by the glovebox believe it or not...
Open it up and take the glovebox shielding plates(can't think of a better way of describing them) out and expect to find the abs ECU. A dodgey plug connection is possibly causing you your tale of woe.
TOFTY
Mon Oct 27, 2008 12:04 pm
will do that tonight
thanks
**BANNED**
Mon Oct 27, 2008 1:22 pm
ABS light feed wires(a thin green and a grey/red)run across the top of the glovebox area.Have a look to see if they have become trapped or damaged.
Youth is wasted on the young.
Mon Oct 27, 2008 1:57 pm
Age of car???
TOFTY
Mon Oct 27, 2008 2:27 pm
88 325 cab
Mon Oct 27, 2008 7:04 pm
Had a feeling you'd say '88 - Doesn't help one way or the other! Around the end of '88 there was a change to the ABS system, when a small silver relay was deleted from the system.
If you have the relay, it is mounted to the right and above the ABS relay, clipped above a bit of metalwork, so not too easy to see. If this relay is present, it's the chief suspect.
Should have asked if the ABS light only comes on when the ignition switch is on?
TOFTY
Tue Oct 28, 2008 9:40 am
not too sure if it comes on or not!
totally lost me on the relay but i will have a look tonight didnt get chance last .
ive had my glove box off lately so my have trapped or knocked a connection like jon said!
but will look tonight brian and thanks :D
