Prop ideas for m30 conversion
- E30 Zone Meets/Events Team
As above, what can you suggest.
Pos 3 for engine, m20 doesn't fit, and no 328 manual prop to be found yat.
What else is available.
jaffro
ric325i is position3 and the m20 2.5 manual prop fits
Rik178m
Isn't an m3 prop spose to be used for the m30 conversion?
blingsta
- Boost Junkie
I can get you a custom made prop for £80 just need measurment and flange size on gearbox !
m10 gearbox with m10 prop, im sure that works??? can someone confirm this ???
leeparkes
Theres an M3 prop for sale in the parts section,
£130ono!
its worth considering.
£130ono!
Mine is an 320 prop, is thata different size in length to the 325 prop?????
whipsey
yeah the 325 prop is longer iirc
Well tahts wrong then, because my 320 prop is longer by about 1 1/2 inches, so how can a 325 prop fit???
blingsta
- Boost Junkie
eithher go for the M3 prop or custom made jobby for £80 mate.. i had this headache too but couldnt find a M3 one at the time.. was much quicker to get a custom made jobby for half the price !
jaffro
whipsey wrote:yeah the 325 prop is longer iirc
its the 320 prop thats longer the 325 prop is slightly shorter as the 325 gearbox is longer than the 320 box
Weel that explains that then, bound to have one of those.
charlE30
M20 prop wont bolt up to the M30 gearbox as the output flange is much bigger, you'd need to change the output flange (if that's possible) for the M20 item.
Rav it would be worth seeing if Toby still has his, it bolts straight up with no messing
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
whipsey
yep thas the onejaffro wrote:whipsey wrote:yeah the 325 prop is longer iirc
Already taken it off and tried the m20 one.I think i'm going down the custom route as I have the e34 and the m20 props here to hand, and really don't want to shell out on another prop and then have to try and get rid of these 2.M20 prop wont bolt up to the M30 gearbox as the output flange is much bigger, you'd need to change the output flange (if that's possible) for the M20 item.
Theres a guy in coventry, Radford who makes custom props, so ill be off there tomorrow.
