removing window glass,
n1ght28
Wed Sep 24, 2008 8:02 pm
hey i've got a 318 touring 1990 and i'm trying to remove the glass from the drivers side door and i can't quite see what i'm meant to do, the haynes manual says
1 Disconnect the battery negative cable.
2 Remove the door trim panel and the plastic
water shield (see Section 12).
3 Prise the door inner and outer weatherstrips
4 Raise the window so that the mounting
bolts can be reached through the access hole.
If electric windows are fitted, temporarily
reconnect the battery cable to accomplish
this.
5 Support the glass, and remove the retaining
bolts securing the glass to the regulator.
6 Lift the window glass up and out of the door
window slot, then tilt it and remove it from the
door.
7 Refitting is the reverse of removal.
but i can't see any mounting bolts, the bottom of the window is held in with the catch at the two pints it touches the window regulator, it looks like the window just sits into these an could be pulled ou but try as myself and my bro might they don't budge an inch, i've attached photos of the catches at the end of the windows, if anyone had expereince of working wh these catches please give me some advice. am i just too weedy, is there a secret bolt hidden somewhere, please help!!
http://picasaweb.google.com/cannonrj/Un ... 4746575266
http://picasaweb.google.com/cannonrj/Un ... 6527454018
http://picasaweb.google.com/cannonrj/Un ... 1623573330
http://picasaweb.google.com/cannonrj/Un ... 2312400850
Wed Sep 24, 2008 10:29 pm
Ignore Haynes!
Only the inner seal needs to come off.
wedge the glass up in place and remove the winder mechanism completely. You may need to 'adjust' the winder as you do this to get the arms with the rollers to come clear of the glass.
Remove wedge, turn glass semi on end, and remove.
n1ght28
Wed Sep 24, 2008 11:16 pm
cheers for the reply Brian just so i'm clear are you saying i need to force the glass out of these clamps,
p.s. i've got electric windows, soes that make a difference,
Wed Sep 24, 2008 11:26 pm
No force required anywhere.
Wedge the window, unbolt the window mech, but leave the electrics connected, and juggle the rollers out of the glass with the window switch.
All very easy.
n1ght28
Fri Sep 26, 2008 12:27 am
brilliant, i'll give it a try in the morning and let you know how i get on, cheers,
thanks for your help,
**BANNED**
Fri Sep 26, 2008 1:06 pm
Glass and the clamp are one unit....
Youth is wasted on the young.
