part number for foam seals on heater box air vents please
A1BMW325iSport
Post Tue Jun 21, 2005 5:04 pm
anyone know part number for foam seals on heater box air vents please?
i`m replacing the complete dashboard, the foam that seals the dash vents to the heater box i can`t find on the ETK anyone help me out please?
Thanks Matt.
ian332isport
Post Tue Jun 21, 2005 9:10 pm
I think you need one of these:
64 11 1 370 937 - Gasket - Approx Ԛ£16
It has the big rectangle in the middle, and the two smaller ones off to the sides.
Cheers,
Ian.
A1BMW325iSport
Post Tue Jun 21, 2005 10:52 pm
thanks Ian
mrLEE30
Post Wed Jun 22, 2005 5:43 am
Mate did the same and just used aircondition filter foam and cut it out to fit, cost me pence and works as good as before. Not sure where you would buy it in uk its basically a piece of foam gauze. why not try a furniture shop and ask if they have any thin strips of foam lying around. make a template from paper (adults must supervise if using sharp sissors) then cut out yer foam and easy job.
16 quid sod that!!
mrlee
