red exclamation mark on
mhuk
Mon Sep 15, 2008 6:36 pm
I bleed my brakes again today and now I have the red exclamation mark on all the time.
To me that means the hand brake is pulled up but it's now. Does it mean something else? I was doing some sliding also :o:
Triumph Spitfire MKIV
BMW E30 325i 4dr rightness
SUbaru Justy Gen2 AWD
stonesie
Mon Sep 15, 2008 6:50 pm
Low brake fluid? maby the float is stuck or the wireing not connected properly?
scotttollan
Mon Sep 15, 2008 6:52 pm
i could also mean brake pad wear that's if you have done them of course
bmw 320i e30
stonesie
Mon Sep 15, 2008 7:16 pm
I thought that was a seperate light, a circle with dashed brackets around it to indicate brake lineings/pads?
Mon Sep 15, 2008 7:21 pm
The red light with the exclamation mark is for low fluid level in the resevoir. Nothing to do with handbrakes or pad wear.
scotttollan
Mon Sep 15, 2008 10:01 pm
oh right sorry
bmw 320i e30
mhuk
Mon Sep 15, 2008 10:26 pm
Thanks, I'll take a look before going to work :-)
mhuk
Tue Sep 16, 2008 10:48 am
Brianmoooore wrote:The red light with the exclamation mark is for low fluid level in the resevoir. Nothing to do with handbrakes or pad wear.
Water right?
It was low and i filled it up and now the light is on and off like a yoyo :-(
ALso the brake fluid was low so I topped it up (more on that later)
Tue Sep 16, 2008 1:36 pm
Water right?
No!! Brake fluid level.
Low coolant light is in the panel in the roof.
