E46 flat battery - jump start or remove and charge?
Morat
Post Sun Sep 07, 2008 10:19 am
Folks,
I'm wary of jump starting a car with so many electronics onboard, but I don't know what effect removing the battery completely will have either. Which is the safer option? Its a new battery, but it went dead overnight :/
cassa-d
Post Sun Sep 07, 2008 10:27 am
Mate my e46 coupe has been parked up for about 5 months and the battery is dead i've jump started it and its been fine just do it from the contact points under the bonnet.
" A FRIEND IN NEED IS A FRIEND WHO CAN STAY AWAY FROM MY E30"
zimmerbimmer1
BMW Parts Meister
Post Sun Sep 07, 2008 10:34 am
If you are in a rush I suggest sticking the side lights on as this should stop any spikes.
If not then yes remove battery re charge it
Morat
Post Sun Sep 07, 2008 10:45 am
Thanks folks, and good tip zimmer!
Morat
Post Tue Sep 09, 2008 2:18 pm
Now running a treat after a good charge. Does anyone know what sort of current these things should be drawing with the key out and (factory) alarm set? I'm starting to suspect a bit of a short somewhere.
