Gary was gonna do the bled and i was gonna put a lock and handle on one of the doors of the unit
we had a look underneath and a small section of brake pipe was corroded, also the two rear bushes on the subframe where shot and the front trailing arms where on the way
none of this picked up by the garage that had done the mot
So its booked into Etech to be sorted
Up on the ramp
Then round to dave ts for some sorting out, pimpmobile in attendance also
we welded up the three tiny holes in the battery tray, described as serious bulkhead corrosion by mot tester
Dave and Wayne then set about the tappets, i never knew how to do these but i do now
Wayne cracks on
added some goodness
coolent change and new hoses,
car is starting to come along at long last, thanks for your help today chaps
