Im stuck nemo'snewenginehas a non working visus and a working one on the old engine.
I cant get the bloody thing off anyone know
dont really wana buy a new one and pay garage to do it as im bloody skint
i need help
thanks richy
Viscus How do i take the bloody thing off
Richy325iTouring
16azev_needed_for_my_e30
The fan has a left handed thread
Richy325iTouring
worked that bit out just trying to work out how to lock the thing so i can get it off
its doing my nut in
its doing my nut in
JazzMan
I ended up using mole wrench on an old alt belt to hold it still and a hammer on the spanner. Was a major pain in the rear end but got there in the end.
Richy325iTouring
another crack at it
its the one on the old engine being a pain
nt even started the one in thecar yet
Ant
- Retired Team Member
use a long chisel or similar dude
position it so its on the edge of the nut and strike the end with a hammer so as to drive the nut around on the waterpump shaft.
badly explained I know but you get the gist M8 ?
Email FTW
Richy325iTouring
got it off old engine
now to get it off the car
plus its bloody hot
i pick the times to do things
hotter than yesterday im melting and so is nemo
chears ant i got to find a chisel now though
all i got here are my good one and i like them sharp to do my woodwork
plus its bloody hot
How do you manage to keep your horse cool outside the workshop in this hot weather?ant wrote:use a long chisel or similar dude
Use a thin 32mm pen ended spanner (common bicycle size), slip the end on the nut with the shaft vertical, and give it a good belt clockwise (from the front), with a lump hammer.
If you still need to stop the pulley turning, then drill a 6mm hole in the end of a piece of flat steel bar, and fix it under one of the pulley retaining bolts.
Richy325iTouring
all done and working
thanks lads
thanks lads
