How to remove a steering wheel?
StefanAnghel
Fri Aug 29, 2008 3:16 am
Ok guys...a hard one for me...
I found in a break yard near me a M-tech steering wheel but it's locked and the keys are missing
How can I take it off???
wiledw
Fri Aug 29, 2008 5:35 am
If Tec1 wheel prize out centre bmw badge with screw driver or similar and undo bolt.
If Tec2 wheel pull off horn by hand push and undo bolt.
The streering being lock will help as the bolts can a little stiff to undo.
DHFiS
Fri Aug 29, 2008 6:58 am
I used a piece of scrap wood go from the floor up to one of the wheel's spokes (use a piece of cloth to protect it). this stops the wheel turning as you undo the centre nut and avoids putting any strain on the car's steering wheel lock.
hennabm
Fri Aug 29, 2008 7:19 am
The problem is not the undoing of the nut but if the keys are out and the steering lock on - how do you get the wheel off the column. I don't know myself but I'm just trying to clarify the issue. :?
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
Cloud
Mmmmmm Donuts!
Fri Aug 29, 2008 8:06 am
The steering lock doesn't hold the wheel itself, it just stops the bar from turning. It really is as easy as described above, just unbolt the wheel from the locked bar, and it can be lifted off, regardless of whether the steering lock has stopped the bar from turning.
zaust
Zone day release
Fri Aug 29, 2008 8:24 am
Fella, you will have to use some force on ts one, unless you can pop the lock out(mallet and chisel) and then the pin will drop.
M30 Tech 1 Touring on gas.
Fri Aug 29, 2008 9:23 am
Cloud wrote:The steering lock doesn't hold the wheel itself, it just stops the bar from turning. It really is as easy as described above, just unbolt the wheel from the locked bar, and it can be lifted off, regardless of whether the steering lock has stopped the bar from turning.
The steering lock engages with any standard E30 steering wheel, and prevents it being removed!
I get over this problem, when it arises in scrapyards, by ripping off the top column cover, and attacking the alloy of the lock housing where the pivot pin is.
Cloud
Mmmmmm Donuts!
Fri Aug 29, 2008 9:53 am
Brianmoooore wrote:The steering lock engages with any standard E30 steering wheel, and prevents it being removed!
I've learned something! Thanks.
**BANNED**
Fri Aug 29, 2008 12:26 pm
Just to enlarge on Brain's post.When the key is removed,a spring loaded pin engages with the toothed register on the reverse side of the steering wheel.Until this pin is moved down,either by turning the key or as Brian described,the wheel is staying on the column!! Would removing the lock by extracting the shear bolts work?
Youth is wasted on the young.
Fri Aug 29, 2008 12:58 pm
It is also worth only loosening the main nut holding the wheel in place so that it is still attached to the thread of the steering column so that when you give an enormous tug on the wheel to get it off, you don't then smack yourself in the snout with the wheel :D
maxfield
Fri Aug 29, 2008 1:03 pm
E30BeemerLad wrote:It is also worth only loosening the main nut holding the wheel in place so that it is still attached to the thread of the steering column so that when you give an enormous tug on the wheel to get it off, you don't then smack yourself in the snout with the wheel :D
Learned by your own mistake? :)
Ziggy
Fri Aug 29, 2008 1:04 pm
Brianmoooore wrote: I get over this problem, when it arises in scrapyards, by ripping off the top column cover, and attacking the alloy of the lock housing where the pivot pin is.
Yup, nice big hammer & chisel :)
leeparkes
Fri Aug 29, 2008 1:12 pm
use a set of long stilsons or adjustable spanner over the ignition barrel and break it off
you wont get the wheel off with the steering lock on (as ive found out)
Fri Aug 29, 2008 1:14 pm
No, but I was close enough to doing this once and have heard about people breaking noses etc. Live & learn :)
