87 325is idles rough with A/C ONLY
clydesdale
It high idles with the ac on, shut the a/c off and the car idles back to where it should. Any ideas? Thanks
It's supposed to! The ICV can't respond quick enough if the aircon clutch pulls in, so the car might stall at normal idle.
There's a four pin connector hanging off the engine loom just before the ECU plug. The increase idle speed signal goes to the ECU by a pin in this connector. Disconnect it, and the idle will stay as normal.
clydesdale
It is normal to ramp up to 2000 rpm? Wow. That seems high.
Should only go up a few tens of RPM, not to 2000!
Pull the connector that I've mentioned apart, and see what happens then.
clydesdale
I am not sure what connector you are talking about, but I pulled the connector on the back of the idle control valve. When I do this the car then idles down. When I plug it back in, it idles up again. How do I diagnose a bad ICV? I replaced the intake bellows pipe and the other rubber hose off of the ICV. The large intake hose going to the throttle body had a nice 2 inch tear in the bottom. It needed to be changed, but did not change my idle issues.
Connector is a couple of inches away from the engine ECU, and comes out of the large cable that goes to it.
clydesdale
So we are talking about something under the dash then?
Morat
Brian, aren't you meant to be on holiday?
clydesdale
I believe he is, I am hoping someone else will know the answer to this. Thanks.
clydesdale
Anybody know where this plug and harness is located in the car?
clydesdale
Sorry, I need more info. Is this under the hood or under the dash. I thought someone said it hooked to the ecu, which I believe is under the dash. Thanks a ton for your help.
clydesdale
I see the ECU and I see the large bunch of wires going into it. But I do not see what controls the a/c. What color wires am I looking for? THe car is an 87 325is. I looked for a plug that is a few inches before the ECU, but no luck. Any pics of this? Thanks.
asmith88
sept 2008-august 2009, flip thats one long running problem
1990 brilliant red 318 is
clydesdale
Yep, I dealt with it until the end of the a/c season last year and then this year the damn thing did not cool at the start of the season. So, I tracked down my leak and now I would like to track down why the thing will rev to almost 3000 rpm when I push the a/c button.
clydesdale
Fantastic, thanks man.
clydesdale
Does it actually attach to the ecu?
