once i got the 320 back to mine, noticed the fan belt had come off. replaced it and now the alternator doesn't seem to be charging the battery. the battery warning light is not on on the dash, but could this still be the alternator fubar? the cars been standing for about a year with a dead battery so possibly could be battery 2? any ideas?
cheers
battery charging problems.
tom_johnston
- Contact:
<a><img></a><br>
town325i
the light bwouldnt come if the battery was shagged it more than likley the alternator that is fubared put a multi metre on the battery and see what voltage is there if its less than 12volts when running its the alternator
BadDave
With the engine running, you should be getting in the region of 13.8 Volts at the battery.
Have you pulled the caps off and checked to see if there's still acid covering all 6 cells?
If one cell is low then it's probably fooked
Have you tried trickle charging the battery for a day, then fitting it,to see how long it takes to discharge.
Another option would be to go down to your local garage and ask them to check the battery for you
- Brianmoooore
You'll be very lucky if you can bring a battery that's been discharged for two years back to any kind of useful life.
