Cams for m20b25. 535i cam maybe?
tomislav
Post Sat Aug 23, 2008 10:24 am
I'm looking to chuck a cam in my 325i as well as a turbo at some point but was after some recommendations. I also wondered if a 535i cam might go or make a difference
stonesie
Post Sat Aug 23, 2008 1:22 pm
I don't think that a M30 cam will eaven fit the M20 head, the M30 is physicly a much bigger engine and known as the 'Big six'.
Ant at Atech would be worth a call as he specialises in turbo conversions and deals with CatCams, he gets some very impressive results too.
tomislav
Post Sat Aug 23, 2008 4:10 pm
Thank you, back to the drawing board!
reggid
Post Sun Aug 24, 2008 4:39 am
there are plenty of cams for a m20 that you can choose from
Schrick
Catcam
Kent
Piper
Dbilas
the list goes on.......
fowler
Boost Junkie
Post Sun Aug 24, 2008 3:57 pm
Cat cams is best bet as the can do one to suit contact A-tech on 01959-534-718 and dicuss cost
EX A-Tech Workshop bitch !!!
gone but not forgotten
maggspower
Turbo Farmer Tractor Driver
Post Thu Aug 28, 2008 12:02 am
Hi there although you can get cams that are designed to get the best from turbo engines, stick with the standard one as it is much more suited to a F.I engine than a hot N.A cam.
The best bit is you probably have one already :)
cheers maggs
