Thanks and new questions!
tannerman8807
Sat Aug 23, 2008 7:48 am
Sorry guys internet off last night, im stripping the hub of the front strut, there is a large nut, what size is it as need to but one. must be 38-45mm range.
Help as off to shop at 8.30 then i lose the wifes car!!!!
Last edited by tannerman8807 on Sun Aug 24, 2008 10:02 am, edited 1 time in total.
For sale soon, 325 Touring (H) 1991 Jan. Auto 104K, silver BBS (black and silver) Mint sport interior. New front wings, very tidy, all bushes done front and back, Wheel bearings. Available this month. Email for further
beardymat
Sat Aug 23, 2008 8:07 am
its either a 36 or 34mm. i got caught short at work the other week doing mine and had to grind down the wall on my 36mm impact socket so it would fit inside the hub. you shouldnt have that problem with a standard socket.
sorry i cant be more exact but with the socket being a tight fit into the hub i couldnt tell if it was the correct size but i didnt check at the time as i didnt care as it did the job.
just had an idea, ill be back
tannerman8807
Sat Aug 23, 2008 8:09 am
Waiting thanks
beardymat
Sat Aug 23, 2008 8:12 am
damn, idea no good :(
sometimes on realoem it gives sizes on nuts and bolts, nothing on the hub nut though.
tannerman8807
Sat Aug 23, 2008 8:14 am
Thanks anyway, ill take a plastacin mould to the shop :o:
ric325i
Sat Aug 23, 2008 8:22 am
36
ric325i
Sat Aug 23, 2008 8:24 am
just been out to teh garage in my jim jams with my breakfast getting soggy to find teh socket i used for teh job over a year ago.
for teh hub nut im 90% sure its a 36 as its teh same size as teh drift shaft hub nut on a 5turbo.
90% it was a year ago! hope this helps? now to my soggy crunchy nut
tannerman8807
Sat Aug 23, 2008 8:28 am
Ta
tannerman8807
Sun Aug 24, 2008 10:01 am
Thanks chaps it was a 36 and my dad had one, so saved lots of dosh there. What a job though, after removing nut and pulling off hub the bearing fell apart leaving the rear case still on the spindle. Is this normal? happend both sides. Is it easy to get back together? When i took of the rears a while ago hade to buy new bearing complete.
I am also replacing everything rubber , so new wichbone mounts srop links etc. can wait to see how she handles. Whats the best way to get the wishbone mounts in the bracket?
beardymat
Sun Aug 24, 2008 11:13 am
the bearings will fall apart and its good practice to replace them. mine came apart but as it was a sunday and i was replacing the disc back plates on a whim i retrieved all the parts, cleaned them and regreased them with some high temp grease and put them back together. the rear part needs to be pulled off the stub axle and refitted to the bearing. mine has been fine since by the way :D
the rear wishbone mount fits into the lolipop mounted to the underside and these can be pressesd in using a vice, they are a bugger to fit to the wishbone itself but most people use fairy liquid to fit them. dont use wd40 or such like as the bushes need to dry out to work properly.
