rear wheel bearings
stevieallstars
Mon Aug 18, 2008 9:47 pm
hi guys
finally got an e30,
only thing it needs is a rear wheel bearing
i was wondering can these bearing be changed without special tools or will i have to pay to get it done at a bm garage/dealer?
i know a mobile mechanic and he says he can do it
but i would rather check with you guys first
let the professionals do it?
or
let mr (i know everything)mobile mechanic do it?
ta much
steve
Mon Aug 18, 2008 9:49 pm
it is a ball ache of a job, if the mobile mechanic says he can do it and you trust him then go with your instinct
stevieallstars
Mon Aug 18, 2008 9:58 pm
that was quick
well its my first e30
my daily driver is an e36 that gets left in the street that i dont care about
but the e30 is so good and genuine i just dont trust anyone on it
but if its a pig to do i`ll just get my local dealer to do it then at least they know what their doing (i hope)
any idea how much pennys it would be in the ££dealer££
thanks
Globulator
Mon Aug 18, 2008 10:01 pm
If you change the bearing then (ffs) change the backplate at the same time if it doesn't look mint.
The ease of the job depends how easily the axle slides out of the hub. Sometimes they just don't.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
stevieallstars
Mon Aug 18, 2008 10:15 pm
so it can be done without the fancy special tools?
Mon Aug 18, 2008 10:21 pm
where are you located?
stevieallstars
Mon Aug 18, 2008 10:22 pm
between eastbourne and brighton
Mon Aug 18, 2008 10:25 pm
try and seek out your local independent BMW specialist, you'll get totally raped by the dealer at £100+ per hour labour.
Wheel bearing you can get from a local motorfactors, shouldn't be more than £25 each and that's dear, any discount and could be less. Backplates are a Dealer part at about £15 each
stevieallstars
Mon Aug 18, 2008 11:06 pm
i got a bearing for £23 from my local motor factors
googled for independents in sussex one that stands out is thwaites
it would be good to know if any one in here knows any other local specialists in sussex
dannyboy759
Tue Aug 19, 2008 2:26 am
I made a tool to do mine with, a piece of studding, a metal plate and some nuts from work and part of the subframe bush tool i made.
It can be a pain of a job but mine came out ok with no probs.
stevieallstars
Tue Aug 19, 2008 8:54 am
the mobile mechanic that seems to think he knows everything has quoted £40
but the way he talks i dont think he knows whats involved in the job,,,
and how long would it take to do,,
abelai
Tue Aug 19, 2008 10:35 am
He probably thinks it is a simple wheel bearing like the ones you get on the rear of front wheel drive cars. Print a picture off realoem for him and he'll soon realize that he's not doing that for £40. I wouldn't do it for less than £100 a side but that would be genuine bearings as some people have said the GSF and ECP bearings don't last more than a year.
If I can't fix it I'll f**k it up so bad nobody can!!
stevieallstars
Tue Aug 19, 2008 11:55 am
just checked how much it would be at my local dealer,,,
wait for it,,,
£240 :eek:
thats genuine bearing at £110 lol
so im going to try a local classic car garage and see if they can help
Tue Aug 19, 2008 12:40 pm
£110 for a bearing, oh how I laughed.
It's probably the same SKF bearing that's £20 at the local motor factors
