Hi, will the front suspention from E30 318 , 325 fit m3 e30?
If to buy Bilstein, which of them will suit m3 the most.
If i gonna keep Koni ajustble and put standard M3 e30 spring with
them , is it gomma make it worse?
m3 e30 suspention
- jamiecollins
If you mean the damper inserts only, yes they do fit. I bought Bilstein inserts and Eibach springs for my M3 and the inserts are marked up as 318's , they've been fine for the last three years or so.
Jamie
Jamie
