Hi Paul, I'm lookin prices for a few e30 parts here and some e12 ones -not sure if you're selling bits for non e30 beemers?
e30 parts:
HOSE 11151721908 x1
intake m'fold gasket:
11611717761 or 11611734684 x1
I need new plastic clips that hold the hockey stick shaped trim panel bits on the car, I think its: 51131870459
and the gaskets that go with them are
51131858962 or 51131904479
x6
E12 Parts
Restoring this old m535i I'm welding it up from the inside, and sorting the interior at the moment, the following are mostly small interior parts that need renewing, apologies for the very long list, the interior is a mess:
boot bmw badge 51141872327
cover for around stereo 65111363723 x1
screw 07119902497 x8
spacer ring 65111374608 x8
body nut 07129925708 x8
cigar lighter support 61341363854 x1
bulb 1.2w 63217167000 x4
switch cover for big e/w switch 51411823490 x1
ACCELERATOR PEDAL
accelerator pedal assy 35411105414 x1 (not sure what this contains -I really just need a new pedal)
lever 35411113729 x1
PEDALS/STOP LIGHT SWITCH
circlip 35211118373 x1
rubber pad 35211108634 x2
hex screw 35111150944 x6
stopper 35411108277 x1
gasket 35111103543 x1
STEERING COLUMN TUBE
Fracture/ shear bolts 32321109641 x5
Wave washer 07119932099 x4
Screw 07119906436 x2
Screw 07119906437 x1
Screw 07119907627 x2
Wave w 07119932047 x2
Hex nut 07119922038 x2
STEERING COLUMN
Lever 32311152992 x1
STORING PARTITION
Screw 07119902428 x2
Hex nut 07119905543 x1
Washer 07119936425 x1
Spacer 34321108306 x2
Hex screw 07119901334 x2
HEATER SWITCHES
Screw 07119902497 x3
Nut 07129926107 x2
Self tapper 07119907789 x2
FRESH AIR
Screw 07119902423 x10
Steering wheel badge 32332206203 x1
Hose for wipers etc. 61 66 1 357 388
Rear window shelf schwartzgrau 51461850455 x1
I doubt I want to know but how much is the brake master cylinder from BMW?
Thanks Paul
Kevin
A few bits
zimmerbimmer1
- BMW Parts Meister
Sorry for delay
e30 parts:
HOSE 11151721908 x1 £8.15
11611717761 £6.66
11611734684 £5.09
51131870459 £1.34 for 6
51131858962 £0.76 for 6
E12 Parts
boot bmw badge 51141872327 £16.49
cover for around stereo 65111363723 x1 £3.78
screw 07119902497 x8 £1.02 for 8
spacer ring 65111374608 x8 £1.02 for 8
body nut 07129925708 x8 £1.02 for 8
cigar lighter support 61341363854 x1 £3.67
bulb 1.2w 63217167000 x4 £5.48
switch cover for big e/w switch 51411823490 x1 £9.47
ACCELERATOR PEDAL
accelerator pedal assy 35411105414 x1 £13.32
circlip 35211118373 x1 £0.27
rubber pad 35211108634 x2 £4.10 for 2
hex screw 35111150944 x6 £10.54 for 6
stopper 35411108277 x1 £0.31
gasket 35111103543 x1 £1.48
Fracture/ shear bolts 32321109641 x5 £3.76 for 5
Wave washer 07119932099 x4 £0.73 for 4
Screw 07119906436 x2 £0.26 for 2
Screw 07119906437 x1 £0.24
Screw 07119907627 x2 £0.39 for 2
Wave w 07119932047 x2 £0.26 for 2
Hex nut 07119922038 x2 £0.26 for 2
STEERING COLUMN
Lever 32311152992 x1 £4.59
STORING PARTITION
Screw 07119902428 x2 £0.26 for 2
Hex nut 07119905543 x1 £0.16
Washer 07119936425 x1 £0.13
Spacer 34321108306 x2 £0.63 for 2
Hex screw 07119901334 x2 £0.47 for 2
HEATER SWITCHES
Screw 07119902497 x3 £0.39 for 3
Nut 07129926107 x2 £0.32 for 2
Self tapper 07119907789 x2 £0.26 for 2
FRESH AIR
Screw 07119902423 x10 £1.59 for 10
Steering wheel badge 32332206203 x1 £13.54
Hose for wipers etc. 61 66 1 357 388 £2.75 per metre
Rear window shelf schwartzgrau 51461850455 x1 £26.46
I doubt I want to know but how much is the brake master cylinder from BMW? £372.24
Thanks Paul
Kevin[/quote]
e30 parts:
11611717761 £6.66
11611734684 £5.09
E12 Parts
ACCELERATOR PEDAL
STEERING COLUMN
STORING PARTITION
HEATER SWITCHES
FRESH AIR
Thanks Paul
Kevin[/quote]
anisotropy
Hi paul, thanks for your help. Sorry for delay I've been away.
I'd go for all this stuff, I've just added a few items on to the end of each list for prices.
e30 parts:
11611734684 £5.09
+ AIR HOSE 13411721909 x1
and two new plugs for rear footwells (can't find pn)
and bulb socket 62111376716
E12 Parts:
ACCELERATOR PEDAL
STEERING COLUMN
STORING PARTITION
HEATER SWITCHES
FRESH AIR
BODY NUT 32412482060 x10
HEX HEAD SCREW 07119916967 x10
PROTECTIVE PLUG 17114670114 x10
HEX HEAD SCREW 07119901294 x2
BODY NUT 07129901649 x2
I doubt this would be the sort of thing to post but:
trunk partition: 41131819406 x1
Kevin
e30 parts:
11611734684 £5.09
E12 Parts:
ACCELERATOR PEDAL
STEERING COLUMN
STORING PARTITION
HEATER SWITCHES
FRESH AIR
Kevin
anisotropy
bump
and now need trailing arm bushes for e30
zimmerbimmer1
- BMW Parts Meister
anisotropy wrote:Hi paul, thanks for your help. Sorry for delay I've been away.
e30 parts:
I might be able to send it but there would be a charge for this due to its sizeanisotropy wrote: I doubt this would be the sort of thing to post but:
Kevin
Trailing arm bushes £13.51 per side
Regards
Paul
anisotropy
Cheers I was just curious about price I suppose - I don't think it would be worth the risk posting.zimmerbimmer1 wrote: I might be able to send it but there would be a charge for this due to its size Paul
Trailing arm bushes for the e30 -is that for 2 each side?
Many thanks for your help
zimmerbimmer1
- BMW Parts Meister
Priced at £86 for the panelanisotropy wrote:Cheers I was just curious about price I suppose - I don't think it would be worth the risk posting.zimmerbimmer1 wrote: I might be able to send it but there would be a charge for this due to its size Paul
Each kit has 2 bushes in it, 1 kit per side
anisotropy
Thanks Paul, should be able to give you a ring during the week.
Kevin
Kevin
