Sorry if for basic questions, haven't done this before. I need to replace front brake pads and disks on my 320i touring (post '90). After visiting ECP website this is my shopping list:
101110045 E30(NOT M3) FRONT BRAKE PAD Z1 11.88 -£20.90 (x2)
106110035 GIRLING E30 9/82-6/94 Z1 6/88-6/91BMW SENSOR FT 250 mm 1per/ax -£4.68 (x2)
104110080 E30 O.E F/BRAKE DIS ATE E30 VENTED (EXCEPT M3) -£21.70 (x2)
- Is that all I need, am I missing something?
- Would I be better off with OEM brake pads and discs? Car is not used for trackdays.
- What brake fluid should I get? (I'll be changing it too)
Sorry for the generic questions, just want to make sure I'm getting the right parts before spending money. Thanks in advance.
Brake shopping list
- Brianmoooore
BMW commonly source a particular part from more than one manufacturer, so more than one make will be OEM.
ATE are one of the OEM manufacturers for the discs, as indicated by the '0' at the end of the ECP part number, so these will be fine.
I don't know what makes you think the pads are ATE, but the '5' at the end of the part number indicates that they are supposed to be as good as OEM, but are not actually OEM.
