PAS fitting - remove subframe?
A1BMW325iSport
Post Sun Jun 12, 2005 12:49 pm
Hi,
on my 325i....
manual rack came off no probs, but the power rack thats going on is having none of it, whats the best way to get it on?
lift engine with crane slightly? drop subframe?
A1BMW325iSport
Post Sun Jun 12, 2005 2:32 pm
anyone?
Post Sun Jun 12, 2005 2:42 pm
Should nearly go in. Just bend the lower brackets down very slightly. They'll pull up OK when you tighten the bolts.
Martinaston
Post Sun Jun 12, 2005 2:44 pm
support tha engine and drop the subframe.
use a lump of wood at the exhaust side to stop it falling over.
Post Sun Jun 12, 2005 2:54 pm
I've never messed around lifting an engine to change a rack yet, including with a M50 conversion.
A1BMW325iSport
Post Sun Jun 12, 2005 5:38 pm
cheers guys i`m going out now to have another go at it
A1BMW325iSport
Post Sun Jun 12, 2005 8:58 pm
cheers Brian, bent brackets down as suggested it went straight on then.
Matt
