Engine is racing and wont idle properly
Richy325iTouring
put the new engine intoday and now the bloody thing wont sit at proper idle revs it running at over 2kand then creaps up to 4.5k
this is freaking me out
any ideas what it is been bugging me for hours now and we seemed to have checked everything.
Thanks Richy
Thanks Richy
320Touring
ICV-is it dirty or not got an airtight connection?
AFM-no unmetered air getting in through a split in the pipes/TB tightened correctly?
ECU-did you give it the minimum 10 mins sitting at idle to get base settings?
Fuel pressure too high?
sorry thats all I can think of-hope you get it sorted!
Martinaston
sounds more like you've got the wrong parts on there
air flow or even ecu. Is the loom damaged?
Chaos
they both the same parts that were on it originallyMartinaston wrote:sounds more like you've got the wrong parts on there
Chaos
causing havoc and mayhem wherever i go
Chaos
do u have to do that everytime u disconnect battery then ?320Touring wrote:ECU-did you give it the minimum 10 mins sitting at idle to get base settings?
Chaos
No one's mentioned the obvious - throttle cable too tight.
Chwck there is a little slack on idle.
Richy325iTouring
throtle ok
seems ok this morning
might have been wet but i changed the breather from the fuel pressue regulator to the inlet
psychochild187
try a vacume hose somewhere it would sent the idle i bit mad.
Richy325iTouring
checked everywhere for vac leaks cant find any
whole car is doing my nut in
well all cars after the week ive had
thinking of just breaking nemo now ive really had enough.
craigieeb
what does it do when you try and rev it up?? does it go smothley or does it only go so far, coz i remember when i done 1 a while ago the syptoms sound just like yours, it was a verry fcuked up idle where it was just going up and down, and when i tryed to rev it up it seemed like the limiter had been brought down to about 4000rpm, and i tracked it down to the conections next to the reset thing on the engine, i think one is the timing sensor, and the other is erm.....
http://img299.echo.cx/img299/6728/00004147eu.jpg
all i had done was connected them up the wrong way round
M50 Turbo!!!
I shall say no more
Martinaston
craigieeb
the other is the oil pressure switch
i thought somthing similar but those two plugs are the opposite way up to each other and with a straight engine swap would probably not be touched. Although it would explain the increase in rev's
Karan
make sure its all wired up right......
Martinaston
Richy
does the throttle close all the way ? not just the spring on top.
if so what happens when you pull the icv out and block the holes ? (hold the throttle open slightly to compensate but leave the loom connected)
Richy325iTouring
all wired up right idle down now standard chip in but its still idlleing high.
runs like a bag of olts and is over fueling to buggary.
had enough of it think im gona get rid cant be doing with teh hassle and buy myself a denzil heap of shit just for work.
fcuk the cars now
fcuk the cars now
dazleeds
- old skool raver
i know them feelings mate but dnt do it nemo has been the talk of the site at times and must be fixed Daz leeds
and having seen the pics of you spinnin nemo and doing doughnuts it seems nemo was once a good car and will be again i know your piss*d off but hang in there and when its fixed hang the arse out smile and be happy again mate good luck
www.oldskoolfantasy.co.uk
Richy325iTouring
one thing left to try
but its too late to do it now
SCOTT325SE
And thats what we were just talking about i guess?
Richy325iTouring
sure if fellaSCOTT325SE wrote:And thats what we were just talking about i guess?
just hope its something stupid so i can have my car back
High idle and over fueling sounds like blue temp sensor. You sure you got the right connector on it?
Richy325iTouring
yep i have some mechanical knowladge lolBrianmoooore wrote:High idle and over fueling sounds like blue temp sensor. You sure you got the right connector on it?
there a new one fitted to the engine though
was gona swap that with the one on my engine but i cant get at it properly and realy wana take the inlet off to do a bloody sensor
SCOTT325SE
i thought that you would keep your old inlet anyway mate, as its black
