318i difficult to start warm
peterjcollins
Sat Jun 21, 2008 6:50 pm
Hi,
MY 318I WILL START OK FROM COLD BUT TAKES ALOT OF CRANKING TO GET IT TO START WHEN WARM, aNY SUGGESTIONS GUYS
CHEERS
Dave_M3
Sat Jun 21, 2008 7:14 pm
I had this problem too for a while in my iS, it fixed itself again somehow though :mad:
Myke_Gee
Thu Jun 26, 2008 9:56 pm
Anyone else? Because mine has started to do the same this week on a couple of occasions!!
secondtimelucky
Thu Jun 26, 2008 11:00 pm
Blue temp sender, common problem and easy fix :D
Wanted: Any old component speakers, complete or separate parts, let me know what you got :D
Myke_Gee
Fri Jun 27, 2008 12:22 am
peterjcollins
Wed Jul 02, 2008 8:07 pm
I have replaced the blue temperature sender but the car is still the same. will start fine from cold but if it has been run and is hot the car will crank several times before it will fire. I am beginning to think it is a lack of residual fuel pressure either the pump non return valve is faulty or may be an injector is leaking. I am contemplating which to go for first.
