Decent Budget Brakes for a 320i
TheMonzta
Tue Jun 17, 2008 10:37 pm
Can anyone recommend decent but modestly priced front pads and discs for my 320i Touring? I would have preferred to use proper BMW ones but budget restrictions mean I have to go for cheaper option but I desperately want to avoid nasty pattern items that'll squeal like a pig eventually.
Other than discs and pads what else will I need?
1991 Honda Civic Twin Cam
1996 VW Golf TDi
2001 BMW 540i Sport
Awaiting the next E30
projectmick
Tue Jun 17, 2008 10:40 pm
Could try ebc brakes - not sure how they compare in price to oem, but hear they are pretty good. They do ultra silent brakes (or something along those lines!) and green stuff pads.
Also get some decent braided hoses from goodridge or similar.
"Quattro ist fur sissies"
www.mikemasonphoto.mfbiz.com
march109
Tue Jun 17, 2008 10:44 pm
Stock all the way.
Omi
Witty custom rank.
Full service on your brakes will work wonders, to be honest. Standard stoppers are really good when kept tip-top.
New fluid, strip and inspect everything, replace/clean as required, bleed 'em through and see what you think before spanking any major cash on upgrades.
I think stock vented fronts and rear disks will cope with most things. When you go beyond that point, go the whole hog and get one of the available multi-pot huge jobbies.
...or is it?
TheMonzta
Tue Jun 17, 2008 10:50 pm
I'm not going for any upgrades or expensive stuff like that. I just want straightforward replacement discs and pads to get me through the next couple of years or so. I will be flushing through my system with fresh fluid and replacing anything that looks tired or had it.
What's the stuff like from Euro Car Parts and GSF?
1996 VW Golf TDi
2001 BMW 540i Sport
Tue Jun 17, 2008 10:56 pm
monza get ATE superblue DOT 4 brake fluid it's £10 a litre and you can't go standard fluid when this is about for the same price
TheMonzta
Tue Jun 17, 2008 11:51 pm
Cheers for that Simon. Can you recommend any particular make of disc/pad as well? GSF and Euro Car Parts all stock items from companies like ATE, Ferodo, Mintex, Girling etc. :?
1996 VW Golf TDi
2001 BMW 540i Sport
stonesie
Wed Jun 18, 2008 1:39 am
Well you wont go wrong with any of those brands really, avoid Trupart like the plague, i had to fit a set of thier pads once because that was all i could get hold of and i had heard the first touch of metal-metal.... after bedding in i tested them, 1 emergency stop from 70... que pedle in the carpet and smoke billowing from both front wheels, can't blaim the discs, they were brembo max's.
I would either buy brembo or ATE discs and use TEXTAR pads from GSF (textar are what BMW use as standard)
TheMonzta
Wed Jun 18, 2008 3:09 pm
That's just the sort of info I'm after stonesie.....thanks for that. 8)
1996 VW Golf TDi
2001 BMW 540i Sport
