Slightly pitted block, can I help it before fitting new HG.
pictonroad
Thu Jun 12, 2008 2:58 pm
I'm verging on the edge of bolting my car back together with a new head gasket, the head's been skimmed and rebuilt at great cost...
My block is slightly pitted, especially around cylinder 6. Will this be a problem? (I'm not taking the block out!)
will the gasket take up the slack or is there a sealant I can use.
I'll try and get a picture later, but pics don't always convey the story.
Cheers,
James
Thu Jun 12, 2008 3:01 pm
I recently had a similar problem with an MG Midget 1275cc engine, between the middle cylinders. A light cleaning with a fine wire brush and fine sandpaper plus new Payen head gasket and it's been OK since, with even compression across all four cylinders. I did however torque down the head bolts a little tighter than the book figure.
mash320i
Thu Jun 12, 2008 6:19 pm
as long as it isnt to bad, i wouldnt worry about it
Thu Jun 12, 2008 7:48 pm
Depends where the pitting is. Lay the head gasket on the top of the block, and if you can see all the pitting through the various holes, there won't be a problem. If it encroaches on the area covered by the fire rings, then the block needs skimming.
pictonroad
Thu Jun 12, 2008 9:35 pm
nah, the few mm around the bores is good, it's beyond the 'metal rings' that the pitting has occured.
SPADGE
Thu Jun 12, 2008 9:39 pm
It'll be fine mate. Best of luck with the re-build and make sure everything is clinicly clean before re-assembly.
