worries
chieftouring
would it be ok to start and idle my 2.5 engine on a 2.0 ecu and meter to test the engines ok b4 i start throwing anymore dough at it?
craigieeb
you could put the ecu on but it will under fuel for sure, and i think the afm will be ok, im sure there just the same
M50 Turbo!!!
I shall say no more
Templ8e30
The 2 litre and 2.5 litre AFM's are different.
It will be ok to run the 2.5 on a 2 litre ECU for a short time, the fuelling will not be massively different as the fuel pressure is higher on a 2.5 anyway.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
dazleeds
- old skool raver
as above
hi iain hows it goin? saw adam yesterday he,s all giddy now fitted loom and she runnin do you have any plans for doing the towbar like yours???
cheers Daz leeds
ps what di you use to paint adams rocker cover and inlet???
cheers Daz leeds
www.oldskoolfantasy.co.uk
