Bugger your on holiday!
Can you check the prices are correct and maybe add the missing part numbers please Paul?
When you get a spare 10 mins of corse...
Pair of E30 M3 eccentric top strut mounts (31331139484) - £94.41 each
studs x6 (31331092886) - £3.56 for 6
nuts x6 (31331092887) - £0.95 for 6
Pair of E30 M3 eccentric lollypop bushes (31 12 9 061 222) - £20.00
Pair of front ARB bushes - £18.55 pair
Nuts, bolts & washers to suit the ARB mounts & drop links - extra £5 per link.
Drop Links (31351091764) - £TBA pair
N/S Track control arm (31121127725) - £TBA
O/S Track control arm (31121127726) - £TBA
Rear.
Pair of E46 M3 cab top shock mounts - £33.29 pair
Pair of E30 rear beam bushes - £52.39 pair
Set of trailing arm bushes - £25.74 per side
or
Eccentric trailing arm bushes - £25 the pair you need 4
Pair of ARB bushes - £5.68 pair
Pair of ARB drop links - £20.62 pair
Nuts, bolts & washers to suit the ARB mounts & drop links, trailing arms and rear beam - Extra £8 per side
3.0 / ZM3 Differential mounting bush (33 17 2228 425) - £21.34
OBs
_________________
Paul prices please
zimmerbimmer1
- BMW Parts Meister
[quote="OBs"]Bugger your on holiday!
Pair of front ARB bushes - £18.55 pair need to know chassis for suspension spec
Drop Links (31351091764) - £54.03 pair
N/S Track control arm (31121127725) - £92.81
O/S Track control arm (31121127726) - £92.81
Rear.
Pair of E46 M3 cab top shock mounts - £33.30 pair
Set of trailing arm bushes - £12.88 per side
or
Eccentric trailing arm bushes - £16.12 per side
Pair of ARB bushes - £5.68 pair need chassis number to check vehicle spec
Pair of ARB drop links - £23.50 pair
Regards
Paul
Rear.
or
Regards
Paul
