e36 328 headgasket
harry_p
Post Fri May 23, 2008 11:48 pm
anyone done one, how tricky is it to do in the grand scheme of things?
got a mate who needs his doing and said i would look into it.
anything particularly difficult about it? any online resources / manuals that are worth a look? any weird specific tools needed?
cheers,
harry
Post Sat May 24, 2008 8:42 am
There are a few special tools, IMO the only one that is really needed is the cam locking tool.
Be sure to have the head pressure tested as they often crack after overheating, especially if the cooling system has been neglected
Andyboy
Alpina Colada
Post Sat May 24, 2008 3:19 pm
If it's been overheated, forget it. Put another engine in. The head bolt threads in the block are guaranteed to srtip on the final 90 degree tighten and if it's a steel liner block, the alloy between the liners will have sunk requiring a full engine strip and block skim.
The Vanos locking tool is the least of your worries with one of these. :cry:
harry_p
Post Sun May 25, 2008 6:38 pm
doh, doesnt sound good.
the bloke took it to a garage because it was overheating, he's found a skimmed and tested 2nd hand head for a decent price and wondered if i'd be able to fit that instead of doing the above to his old one.
doesnt sound like good news though, and i definately don't want to be responsible for stripping the threads in the block :cry:
cheers,
harry
Bob_S
Post Mon May 26, 2008 8:10 pm
i'd back heel it tbh let someone else struggle
Bollocks to this 24v scrap!
Post Mon May 26, 2008 8:20 pm
Sounds like an M52 crank donor!
Do a compression test and a cooling system pressure test on it before doing anything else but will probably be a waste of time because as said, if its got really hot then it will 99% be no good.
