Eh up chaps.
Today I am mostly fitting the ARP rod bolts, oil pump and pickup, sump etc to my S50 engine. Yey.
I dont have an E36 technical manual (anyone know where I can get one??) and need the following torque/angle settings:
Main shell bearings (20 NM, then 50 degrees I think).
Oil pump to block.
Oil pump drive sprocket (reverse thread)
Sump bolts.
Anything else you think I'll need...
Can anyone help?
Many thanks in advance!
Jai
S50 torque/angle settings??
jaistanley
- Homo Hair
Mains is right..
Oil pump to block - 22NM
Sprocket to pump - 25NM
Sump bolts - Either 10NM for 8.8 bolts or 12NM for 10.9
jaistanley
Awesome.. that was trés usefull.
Unfortunately I noticed my crappy 3/8"'s torque wrench no longer reads torques for reverse threads. Did the oil pump sprocket up too tight but didn't damage anything. I also put some thread lock on the sucker..
Cheers Dan!
Cheers Dan!
