another lowering question
E30_Aza
Fri May 02, 2008 6:13 pm
a month or so ago i replaced my front suspention. i know it takes time to settle but i have driven it a good couple of hundred miles and it dont seem to be going know where. i used 60mm jamex springs and bilstein shocks (im assuming standard as they are black and not yellow). have i got the wrong set up????
cheers
aza
BillyWiz
Fri May 02, 2008 7:20 pm
I think they're probably as low as they are going to go. The dampers will not effect the ride height, just your cars ability to absorb the bumps, so the height of the car is certainly nothing to do with your new dampers. If you dont think your car is 60mm lower is it possible you already had none standard springs to begin with? A photo of the car would maybe useful for determining whether it is actually sitting 60mm lower.
cliffybabe
Powered by Nelly
Powered by Nelly
Fri May 02, 2008 9:47 pm
aza u have 16 rims now it aint gonna look as low buddy :?
