325tds engine in an e30?
tommype30cab
Post Thu May 01, 2008 5:16 pm
hi guys, does anybody know anything about this conversion? has it ever been done and is it even possible/ worth it. base car is a pre facelift 325i. thanks in advance.
"Racing is life. Anything that happens before or after is just waiting" Steve Mcqueen
eta
Post Thu May 01, 2008 8:42 pm
Why bother. If you want a low revving high torque engine fit an eta engine instead it will be simpler cheaper and will give you plently of low down torque. It develops 85% of peak torque at 1650 rpm by 2000rpm 90% of peak torque is available. Torque peaks at 177 ft/lb at 3250 rpm. Rev limit is the same as the diesel but its "top" end is likely to be more
lively. I have a eta E28 and acceleration feels constant throughout its rev range which is unlike a TD which will surge when the turbo kicks in and looses it above 3500 rpm. With your 325i diff you will 0-60 of about 8secs as well (if yours a manual). The eta is also very quiet.
tommype30cab
Post Thu May 01, 2008 8:51 pm
good point but it isnt diesel, i either have to sell my car to buy a cheaper to run car or convert mine. it is an option though...
Post Thu May 01, 2008 9:02 pm
If running costs are the problem with a 325, then convert it to run on LPG. That's what I did around eight years ago, and have recouped the conversion costs several times over since!
isTURBO
Post Thu May 01, 2008 10:46 pm
Brianmoooore wrote:If running costs are the problem with a 325, then convert it to run on LPG. That's what I did around eight years ago, and have recouped the conversion costs several times over since!
Sorry to barge in but that sounds like a good idea. What would the conversion cost approx and who would be able to carry out this conversion?
Cheers :cool:
Imageselling more bunnies to pay for my conversion
Post Thu May 01, 2008 11:53 pm
isTURBO wrote: What would the conversion cost approx and who would be able to carry out this conversion?
From about £300 upwards, if you get lucky on ebay, and for your second question: You can.
isTURBO
Post Fri May 02, 2008 7:53 am
Thanks for that.
I was under the impression it was alot dearer.
Regards
