pac1982
Mon Jul 22, 2013 5:42 pm
Got rid of the bodge job behind the headunit, looks and sounds a lot better now..........
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Mon Jul 22, 2013 5:57 pm
pac1982 wrote:Got rid of the bodge job behind the headunit, looks and sounds a lot better now..........
Looking very professional! Why can't everyone do it like that from the start.
darkchild
Mon Jul 22, 2013 8:49 pm
darkchild wrote:
jimbom30cab wrote:Hey mate, you can pick up a decent second hand engine on here quite cheap, you should think about changing it
That's if you really need to
Must be a way of keeping her going?
I definitely haven't ruled it out. Tomorrow should reveal the full extent of the damage which will make things a bit clearer regarding what my options are. I've got a garage I can keep it stored away in so there will be no need for a rushed decision.
Its just new engine + other bits it will need over the next 6 months (tax, tyres, exhaust) doesn't make much financial sense regardless of how much I like the old barge!
Well, looks like its going to live again. Its going to cost me £600-£700. A lot of money to spend on repairing an undesirable model but its been such a good car it deserves another chance. £700 doesn't buy much nowadays so I'll stick with what I know. I thought about breaking it but the old thing has too much of an emotional connection due to the trips I've had in it and the various bits I've added over the years. Bl00dy car! I was considering a £1500 E38 as its replacement (frying pan, fire? :D ) but wisely resisted the urge!
Mon Jul 22, 2013 9:44 pm
Well, a 731 cylinder head for a 320i shouldn't cost much, if needed...
darkchild
Mon Jul 22, 2013 9:58 pm
Speedtouch wrote:Well, a 731 cylinder head for a 320i shouldn't cost much, if needed...
One of the few benefits of B20 ownership - cheap spares!
Automaton
Tue Jul 23, 2013 4:39 am
Debating whether to go for BBS Rx 16" wheels.
Opinions?
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls https://www.facebook.com/groups/444263742439145/
G-Bear
Wed Jul 24, 2013 1:17 am
Took it to get tested today... And it passed.
Have put a lot of hours in of late to get it back on the road legally.. Feels good, just in time for a little holiday down to Cornwall..
Gavla
Wed Jul 24, 2013 9:14 pm
Picked her up, finally! And fell in love all over again....couple of pics to follow.
M6luvva
Wed Jul 24, 2013 9:59 pm
Stopped by the paint shop to see how progress is going on my chromie's repaint....prep coming along nicely!
http://img594.imageshack.us/img594/8186/hf01.jpg
Sykopaf
Wed Jul 24, 2013 10:03 pm
Went round a lot of corners sideways. Got a tank slapper on trying to go in a straight line. Lots of fun was had.
4 wheeled toys:
E30 335i (project)
Mitsubishi L200 (redneck wagon)
2 wheeled toys:
Suzuki TL1000S (hooligan)
Yamaha VMax (rocket-ship)
FinalD
Thu Jul 25, 2013 8:06 am
Fitted a new viscous unit on Monday, now the temp needle stays rock solid instead of creeping up....also seem to have a knock on the front end now though. Don't think it is suspension as I checked droplinks and other bits quickly last night and all was solid.
Never ending this fault finding and fixing on the e30. :(
toby
Thu Jul 25, 2013 9:22 am
FinalD - damper collars tight? Yeah constant fault finding is part of the 'fun' init
Thu Jul 25, 2013 9:32 am
Disagree! Do it once. Do it right. Do it all.
Apart from consumables and servicing, it should then cost and need nothing for the next ten years.
toby
Thu Jul 25, 2013 9:37 am
No Brian, and you know because you help everyone fix the problems. Things still go wrong in different places at different times.
FinalD
Thu Jul 25, 2013 9:56 am
toby wrote:FinalD - damper collars tight? Yeah constant fault finding is part of the 'fun' init
I'll have a proper look tonight but I honestly don't know what has now broken, it was totally fine up until I changed the viscous unit. To replace that I removed the front undertray (as I couldn't get the fan out otherwise) and that was it. Quite odd really as I didn't bash anything else in the process. It could just have happened as I drove down my parent's lane full of potholes and I only noticed when I left after doing the fan.
Brianmoooore wrote:Disagree! Do it once. Do it right. Do it all.
So you're saying I should strip the car down completely, undo every last nut and bolt, take the engine totally apart and rebuild it all with fresh nuts, bolts etc? That is the only way to 'Do it once. Do it right. Do it all.'. The car was fine until I changed the fan, so quite how you've come to the conclusion that I've not done something is amazing. It's an old car, parts fail, that's life. :roll:
mikelat
Thu Jul 25, 2013 6:05 pm
Just finished taking my oil pan off as it was drooling all over the transmission etc and found that many of the bolts could be removed by hand! Considered just tightening them to specs and see if the leak stopped but already had the gasket so decided to do a bunch of cleaning and press on. Used the Haynes removal method (loosen the rack and drop the oil pump in the pan) and it came off with a bit of fiddling. What gasket sealer is best as they recommend using one but fail to say which one?
Mike
1990 325i Coupe Gletscherblau_Metallic
appletree
Thu Jul 25, 2013 7:23 pm
Locktite stuff is good if you get the right grade, used it when joing my 6 speed box back togeather and it worked well. It was bright orange and came free from a "local supplier".
Also I ordered the valiters pride black dye to dye my carpet and new shagging blind parcel shelf black. The weekends job. :D
dazleeds
old skool raver
old skool raver
Thu Jul 25, 2013 7:27 pm
errrrrrrm sod all been at work
but I am gonna go and start it in a minute, make sure battery has stayed charged :)
www.oldskoolfantasy.co.uk
Thu Jul 25, 2013 8:54 pm
appletree wrote: It was bright orange and came free from a "local supplier".
Hmm, that sounds like the stuff that forms little rubber balls that break off inside. I've seen oil pump pick up strainers so clogged with the stuff that you wonder how the engine got any oil at all!
All that's needed is a little grease on one side of the gasket to keep it in place.
appletree
Thu Jul 25, 2013 11:01 pm
This was on the gearbox to bellhousing it doesn't have a gasket just metal on metal with a sealer, the stuff I have is used by SEW for sealing there big gearboxes and motors so is designed to work at high temps and with oil contact I think most of the problem is fitterz using gallons of the stuff when just smear do.
zaust
Zone day release
Fri Jul 26, 2013 10:19 pm
Well just smelt fuel on the way to my parents, split on the pipe from fpr to rail !!! Quick snip of some spare hose and home soon. Could have ended in a very warm night...
M30 Tech 1 Touring on gas.
StuBeeDoo
Sat Jul 27, 2013 3:34 pm
What did I do to my E30 today????
I started taking the I.C.E out, and morsels off, in preperation for the remains of the car going to lands a long way east of here to be returned as Tesco Value toasters.
Grrrmachine
E30 Zone Wiki / Team Member
Sat Jul 27, 2013 6:15 pm
Just tightened up the last bolt on an aircon retrofit. Dash out, new heater box in, did all the plumbing, mounted the condensor, fan, drier and compressor, then overfilled it with oil and had to take half the hoses off again :cry:
All the wiring's in, but I just need a few little bits from the dealer before I can fire up the car and bleed the engine, to take the aircon to be vacuumed and charged. Well chuffed.
appletree
Tue Jul 30, 2013 8:43 pm
Well after going to Petes yard (sweep) and sthil sawing half the roof off a late touring shell he had there I spent a good bit of the day drilling out spot welds and very carfully heating up the shitty sealent to seperate the sun roof tray from the roof.
Why have I gone to this extreame? Mine has some rust on the sunroof tray just above the drivers head and is the only rust on a really sold shell so its worth replacing the tray to keep it mint but as these are now only available from Germany and are £504 I have decided to strip this one down and get it sand/beadblasted and powdercoated before it gets fitted to mine probably this winter.
Sorry no pics of me being a rough Kunt stood on the roof sthil sawing it off just the below.
When i got it back
Why they all go rusty. Split sealent that pus the paint of leaving bare metal
Stripped
darkchild
Wed Jul 31, 2013 10:52 am
Bought it a new tax disc. And a new engine. Hopefully it'll be back on the road next week. :D
joeyb
Wed Jul 31, 2013 8:04 pm
My E30 failed MOT on a few silly things this week. When I fitted the B8s I put the offside brake caliper back on with the brake hose twisted 360degrees so they failed it for being twisted, not enough room to move and the tyre fouls on it at full lock. Also failed on a brake imbalance, hopefully that bit was also linked?
Other failure was the front tyre fouling on near side ARB. I'm a bit annoyed about this because the same garage did my tracking a few months back so they could have correctly centred the steering when they did that. I've now manually recentred the steering but now have to pay another £25 for wheel alignment!
Booked in for a retest on Friday so hopefully all will be well. Can't believe it didn't need tyres lol
joeyb
Wed Jul 31, 2013 8:06 pm
Oh and I got my horn working the day before the MOT. Was a loose wire.
oomz1975
Wed Jul 31, 2013 8:19 pm
Refurbished a spare throttle body to replace the one on the car that has developed a coolant leak.
clipper
Thu Aug 01, 2013 2:38 am
At the weekend I gave the E30 its last run out and a good clean....
...before parking it up and tucking it in for a few years sleep while I'm away.
:cry:
G-Bear
Thu Aug 01, 2013 9:35 am
Just got back from a trip to Cornwall with my good lady.
Racked up some 1140 miles. All the hard work on the car in the last month paid off and made for a very pleasurable drive. I think with my calculations and trying to remember how much fuel I put in over the trip, I got around 31mpg (M20B25). Which I was pleased with considering it was mainly A and B roads.
AndyZippy
Thu Aug 01, 2013 4:53 pm
Tax Disc - Yesterday, technically!
joeyb
Thu Aug 01, 2013 4:54 pm
Replaced the infamous heater control resistor pack earlier. I now have four fan speeds! Just hoping it gets through the MOT retest tomorrow, will get it taxed then!
Gavla
Mon Aug 05, 2013 12:39 am
With London being on lock down I gave the old girl a spit and polish
jas025
Mon Aug 05, 2013 5:24 pm
Over the last 2 weekends gave it the full meguires 3 stage bufty treatment, installed the new drivers side underdash panel, got rid of the rattle in the centre console.
Took it to work this morning to go to the ace cafe tonight and now it's p*ssing down.
driftwood
Wed Aug 07, 2013 11:48 am
I made this. It doesn't look like much in the photo but It's a section to repair a rear inner arch. It's not quite finished. I have another couple of sections to make. The lines are tool marks that could be sanded off, but no one will see it so not much point.
