number 3? Wiring set additional fan?
Electric cooling fan ?
steve_k
If you boys read Ians post on the first page all the info you need (and more) is there
steve_k
right then after having a look round i've found this,
http://www.merlinmotorsport.co.uk/p6098 ... _info.html
now what i would like to know is wold this be the right part for the job??
i could do with knowing if this is the correct part before i go & order it & find out it not right.
@danthe, i've read ian332i's first post on this thread & i'm trying to make sense of it lol.
thanks in advance folks.
steve_k
also found these
http://www.demon-tweeks.co.uk/motorspor ... controller
those in this link seem to fit in with ian332i's first post (i could be wrong though
& these
http://www.ebay.co.uk/itm/Variable-Ther ... 3f15512a51
fingers crossed one of these is the right one as it's starting to do my head in now
& these
redcar
Read per it all again and it makes sense. Very clever actually.DanThe wrote:If you boys read Ians post on the first page all the info you need (and more) is there
Thanks Ian
steve_k
jmc330i
Ians info was always more than needed, always very detailed. I wouldnt of wired my S50 up if it wasnt for himDanThe wrote:If you boys read Ians post on the first page all the info you need (and more) is there
I remember him taking the time to email me a lot of wiring info, including the above electric fan stuff.
I cut pins free from the E36 fusebox when I fitted the electric fan to my S50 conversion. I had the complete E36 loom, so cut pins out and traced the wires right back to the fan, switch and earth connections.Brianmoooore wrote: No idea on E36 pins. The pins require a special tool to remove them and leave them reusable, unless you cut the plastic away that retains them.
They fitted the E30 fusebox fine.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
steve_k
i'm starting to think it might be easier to just fit the fan & install a (toggle) switch (somewhere) on the dash & turn it on & off as & when needed, surely that can't be to hard??
jmc330i
A switch on the dash is fine if youre the only one who is going to drive the car and even then you have to remember to turn it on! It might be a little more work to wire in the thermo switch, but its fit and forget. It really isnt difficult to wire in the thermo switch, it took me a couple hours and Im no wiring expert.
A mate had a switched fan on a 2.0l converted Cosra - forgot to tell his MOT man.... you can guess the rest
James
'91 325i Sport
'91 325i Sport
