You are such hard work Neil!
Front Shock's, Which One's?? Update
BristolBulldog
Are we cross talking?Simon13 wrote:they never fitted bilsteins to cabs
fitted standard type bilstein shocks to a cab. that doesnt mean bmw fitted them ok!!!!
cliffybabe
- Powered by Nelly
I know, Im specialSimon13 wrote:they never fitted bilsteins to cabs
Been onto GSF going with them
BristolBulldog
erm... confusing now lol. Glad ur getting some shocks! sorted!!! lol.
BristolBulldog
so you fitted saloon shocks to a cab? cabs are over 100kgs more than a 2 door saloon!
BristolBulldog
erm, yep. lol. never knew! handled really well! i think the cabs 80kg (i removed the rear weight as well)
I went to ecp when i first got the cab, and got pretty much new everything, and they specced me that lol.
the shocks are slightly stiffer than standard (so scared of using that word now!!!), so it could only have helped.
when i first got it all the shocks were shot totally. as in, each shock i removed had no compression at all. They were just loose rods in the chamber!!! then it was majorly comfy!!! although a little lethal in the wet!
doesn't removing that weight in the back of a cab cause more vibration and shake? I thought it was some kind of harmonic damper?
BristolBulldog
Yes it is. Thing is, i knew nothing about the car back then at all. And thought i was being clever. it basically stresses the centre chassis rails and makes a huge difference. How we learn!
i am re-locating the battery to the boot to compensate anyway now, so not too worried anymore, but had inot have been a roll of lead would have found permanent residence there.
Barnz
- Guildford Geezer
Good luck with the GSF Mtecs Neil.... let us know how the ride is.
E34 525tds - on the way to replace 325i
E30 / 34 spares
E30 / 34 spares
cliffybabe
- Powered by Nelly
Barnz PM'd yaBarnz wrote:Good luck with the GSF Mtecs Neil.... let us know how the ride is.
cliffybabe
- Powered by Nelly
Ok just got off the phone with GSF ans they tell me the mtec one's they do are made by sachs/ boge, Are these th esame as the ECP version of the sachs and boge??
cliffybabe
- Powered by Nelly
anyone??
BristolBulldog
don't know for certain, as gsf often use slightly different parts to ecp. they have had "quality" wars in the past. although these are branded parts, so they should be the same.
stuartgallafant
cliffybabe
- Powered by Nelly
Stu ECP dont list them as mtec but i thought same make and all that, hmmm
