That doesn't sound good... (M20 problem)
Post Sun Nov 12, 2006 1:38 pm
Eh, turn the crankshaft another full turn, and check the timing marks again!
Think we might be onto something though. Am I correct in thinking your distributor is sprouting out of the LH side of the engine, and not on the end of the camshaft?
If so, the small pulley on the timing belt has to be timed as well.
**BANNED**
Post Sun Nov 12, 2006 2:21 pm
I am thinking along the same line as Brian,Haynes 815 p101 sect 6 may help....Brian has a better way wiv words than me so he may be able to describe what you need to do as I chickened out some years back when this happened to my 520i!!Remember,it ran before you started,so it will run again!!
NoSkill
Post Sun Nov 12, 2006 2:52 pm
Ah, bit too late, been out and taken the cambelt, tensioner and rad off already :p
I believe the distributer is on the left side of the engine (as you look from the back of the engine at least) as thats where the leads for the spark plugs come from...
My MR2 is being fixed for the mot this week so at least theres not a rush to get this car running again (been able to scrounge lifts/nick my housemates car so far) that soon, so I can take my time to get it running :p
Post Sun Nov 12, 2006 7:53 pm
Some people like making work for themselves! You could probably have got away with repositioning the distributor.
Didn't realise it was one of these antiques with the seperate distributor, or I'd have worked out the problem earlier.
NoSkill
Post Sun Nov 12, 2006 8:06 pm
So whats the plan of action now, set the cam and crank both to TDC again, put the cambelt back on and then fiddle with the distributor?
Post Thu Nov 16, 2006 7:29 pm
DON'T TURN THE CRANKSHAFT WITH THE BELT OFF!! Valves will be bent!.
Put the belt back on without moving anything, turn the crank so that cam and crank marks line up, take the belt off and look for timing marks to line up on the smaller toothed pulley half way up.
Belt, officially, shouldn't be reused, but in practice it'll be OK.
NoSkill
Post Thu Nov 16, 2006 8:16 pm
Surely if I put the belt back on and turn the crank it'll turn the cam at the same rate, or am I missing something?
Going back 'home' to east sussex so it'll be a while till I actually get the time to do this, got my mr2 mot'd now (at silly cost unfortunately but meh :p)
Don't remember another toothed pulley, but might've missed it, i'll have another look on saturday if i get the time...
EDIT:
Just looked in the haynes manual and it makes perfect sense as to where the toothed pulley is for the distributer, so that shouldn't be too hard to sort out...
Post Thu Nov 16, 2006 8:40 pm
Turning the crank with the belt on will turn the cam at half the rate. That's why you thought your timing was 180 degrees out!
As long as you haven't moved either the crank or the cam since the belt was removed, then put it back on and turn until the timing marks line up.
NoSkill
Post Thu Nov 16, 2006 10:54 pm
ah, that makes sense, will do that then, cheers :)
NoSkill
Post Sun Dec 10, 2006 3:32 pm
Ok, I gave up in the end, a bit of uncertainty about my own 'skill' and the fact that it's getting bloomin' cold meant I paid a mobile mechanic to come and sort out the timing malarchy, he came yesterday cost me £45 which i thought was reasonable and she now runs w00t :)
Today I put the rad back together and all that, and then hooked up the battery (albeit it's now completely flat it would appear), moved my mr2 next to it to jump start it and she started up fine, i've put in just under 5 litres of coolant, but it's not fully bled yet of course,
however I have a couple of questions about it, she starts fine (when the jump leads are connected), in fact better than before, however she then goes on to rev upto around 2.5-3k and hold it there, is this because of the dead battery (although it did it even with the jumpleads connected still) or is there another more sinister reason?
Also at ~3k revs, with the bonnet up, it sounds kinda loud and metallicy, is this 'normal', there are no lights on the dash or check panel thing, so i'm guessing it's just the normal noise and i've only ever heard it at those revs from inside the car and with the bonnet down, just want to check...
And again i'd like to thank everybody for their help in getting this fixed, even if it did take ages for me to do it :p
NoSkill
Post Wed Dec 13, 2006 10:18 am
Quick update, I put a fully charged battery in and started it, it was still revving to 2.5k but I went for a drive anyway, after a couple of miles it settled down to idle just over 1k as it was before iirc,
Coolant was fine, fans blowing fully hot and the check panel light not being on, however the dash itself has two problems, both the rev counter and the coolant guage have gone a bit mad, they both flick about like crazy most of the time for no reason I can think of?
And final problem, it used to tick a little bit, but after doing the rocker it now ticks a hell of a lot, it's very loud now, oil seems fine (although could probably do with an oil change) so i'm guessing it's the valve clearances?
