A quick lesson...
25.4mm to a inch, so 1mm divided by 25.4 = 0.03937 inches. So yes 1mm is approx 0.04"
PS i use the Google toolbar spell checker...
Hi Roy, i hope you are well and Jan is getting better ?RJB6 wrote:Hi,Andy not been on here for quite awhile what with the football and Jan has been in hospital.Glad to see your are getting somewhere,what I have done in the past is used play doh it creats a good mould.Took the engine out of mine,looks like I'm abit behind you,but rebuilding it but before I start it I'm going to finish the underneath of the car first.I do believe that the Alpina heads were different from the standard E34.bigger valves and higher lift cam.And if it's a Alpina block they should be light weight pistons fitted as standard and the light weight fly wheel, but someone please correct me if I'm wrong, but that's whats on mine. Pity I'm not ready to do mine or else I could send you pics of what it looks like.But I'm very interested in what you are doing,good luck if you get stuck or need any help PM anytime.
