While we where busy putting the engine in, my friend wanted to check the camshaft. It almost looked like new:
Radiator is also back in the car. Being a 324TD radiator, is a bit confusing where the hose need to go, but with the pictures from the donorcar, it make sens.
All the brakelines, calipers and cilinders are back in. I adjusted the handbrake, so it now grips with a little pull on it, instead on just the last 2 clicks. What a nightmare that was to get it right..
List to get it running is getting smaller:
- + cable from the back
- Engine wiringloom
- heater (picking the best out of 3
- Master clutch cilinder
- fuellines including fuelpump
- pedals
- Exhaust front to back.
- ground cable from the engine to the chassis.
Just a few bits and pieces.
