The idle switch is the miniature microswitch on the right of the pic. If a small amount of thick oil gets into its casing, it will act as an insulator between the closed contacts (still clicks), and when more oil gets in, it will gum up the mechanism and stop it switching altogether (no click).
As can be seen, the WOT switch is much simpler, and less likely to fail, or be affected.
If you are sure that there is no continuity between pins 1 (brown/blue) and 2 (brown), when the throttle is closed, then it's essential you find out why.
M20b25 Running Rich / Failing MOT emissions test
JakeusSnakeus
The TPS is fine. I've just made up some cables for my multi-meter with spade connectors on the ends so i could get better contact on the terminals.Brianmoooore wrote:The idle switch is the miniature microswitch on the right of the pic. If a small amount of thick oil gets into its casing, it will act as an insulator between the closed contacts (still clicks), and when more oil gets in, it will gum up the mechanism and stop it switching altogether (no click).
WOT Pins 3,18 - OK
Closed Pins 18,2 - OK
JakeusSnakeus
I've given up with the Motronic
E30 - 88'
E90 - 07'
F33 - 14'
E90 - 07'
F33 - 14'
Mitchen
Did this ever get solved?
JakeusSnakeus
Not really, I think the ECU was faulty as I'm going down the MS / wasted spark route I wont ever find out
treeman
Hi JakeusSnakeus, feel for you.
Bit of a long shot but I had similar problems in the past and took mine to a bosch specialist who couldn't find the problem until his shirt cuff caught on the afm top cover and it lifted off....it had been bodged previously as this shouldn't come off. Changed the afm for a scrap dealer unit which fixed the problems.
Give the black cover a look/try to see if it has been removed before. In mine the arm which sweeps across all the contacts to give varying resistances had been 're-set' and the arm poorly secured (screw glued on) by some numpty earlier owner.
Good luck.
Good luck.
JakeusSnakeus
Thanks man, i really did want to find out but here's where I'm at now:
http://www.e30zone.net/modules.php?name ... 16#2836616
