Installing new stereo
Junglistjed
Mon Oct 21, 2013 7:48 pm
ill have a look tomorrow at the front speakers to see if the wires are connected to them fine, if they are then im clueless :(
Sanchez
Mon Oct 21, 2013 7:51 pm
If there are and your happy its all wired up correctly then the speakers could be knackered.
You will get there, without a multimeter you have done well so far.
Mon Oct 21, 2013 10:12 pm
You can test the speakers by wiring a 1.5V battery across them briefly - you should hear a click or thud as it moves the cone in and out. :wink:
Junglistjed
Mon Oct 21, 2013 11:02 pm
Just remembered i have a fader, could that be the problem?
Mon Oct 21, 2013 11:17 pm
Yes, possibly - you're better off using the fader built into most modern stereos rather than the old dashboard type ones, as they tend to induce crackle.
Junglistjed
Mon Oct 21, 2013 11:27 pm
im not sure how it works, is there a wire from it to the speakers or what mate?
Mon Oct 21, 2013 11:38 pm
Yes - it goes between the head unit and the speakers. It's just a rheostat (variable resistor).
Junglistjed
Tue Oct 22, 2013 12:02 am
so its actually connected to the speaker cable? and would this actually cause them not to work at all?
Tue Oct 22, 2013 12:03 am
Possibly, if it's a duff unit - try varying it...
Junglistjed
Tue Oct 22, 2013 2:28 pm
not sure if this is good news or not, connected the yellow wires to rear speakers and the rear left came on, nothing came from the blue though.. this also means i have no front speakers? :S and only one working rear haha
the only wires left i have is the white one and a grey one with a red line through it?
Junglistjed
Tue Oct 22, 2013 4:49 pm
Some further invesigation, yellow wires are actually to both left rear and left front so they are hooked up, unfortunately the blue wires are giving me nothing :( think ill just deal with left speakers until i get my upgrades..
what size are the rears guys?
