I like thatross2009 wrote:lol tbh how im building this its going to be capable of silly silly numbers but im not gonna go that mad a few hundred will do me
new monster v8 no 4.0 here !!! Start up vid on page 28 :)
manse73
bruv chariots rule
ross2009
thought you would kevmanse73 wrote:I like thatross2009 wrote:lol tbh how im building this its going to be capable of silly silly numbers but im not gonna go that mad a few hundred will do me
ross2009
got bk on it this morning managed to pull all the sound deadening of the bulkhead was thinking of finding rust
but non what so ever bonus
as my new chevy bell housing wouldn't fit It was either start cutting the tunnel out which I really didn't want to due mainly for mot reasons now as if a cars structure is altered from the manufactures I think I heard it won't pass an mot
So.......
looking at what needed coming out wasn't a lot so fetling time nothing a little and big hammer won't do so got to work this is the result
my adaptor is on order for the gearbox to the chevy bell housing which will look like this
picture is from the website I'll be using a supra clutch plate and a chevy pressure plate there is a slight difference in diameters but this combo has been used before with good results so fingers crossed
will also be using a hydraulic release bearing as there is no room for a traditional clutch slave and fork
also I'm going to be doing the clio servo swap hoping this will give enough rooms for the heads and rocker covers but
I'm not to hopefull so I'm thinking I will have to move the servo over somewhat but until I get the heads I'm not going to know
from this
to this
So.......
from this
to this
ross2009
radiator turned up today not bad for £95
all that was needed is the 2 original mounting points taking of and sits in there a treat
over the weekend I've also realised that my steering joint is in the way of where the starter motor sits
I think the only way to over come this would be to move the steering rack forward by about 20mm
Does anyone know if this would hurt the geometry of the steering? I can't see it making that much difference tbh
I think 20mm should do it
retroboyo
Looking very professional there. Great to see it coming on so quickly. Keep it up
ross2009
professional with a hammer lolretroboyo wrote:Looking very professional there. Great to see it coming on so quickly. Keep it up
thanks
glenn
- Engine Transplant Services
it does look though, like you're holding the starter slightly away from the knuckle. it's difficult to estimate the dimensions though without a dummy fit of the engine.
good progress ross
glenn
ross2009
First picture is actually touching the starter mate
2nd is just undone the rack and pulled it forward I think I'll just make some brackets and move it forward should be fine
Just doing what I can until I get my adaptor I can't really mock anything up
ross2009
my harmonic balencer turned up today another bargain £300 worth for £100
manse73
Harmonic music to my earsross2009 wrote:my harmonic balencer turned up today another bargain £300 worth for £100
bruv chariots rule
manse73
Updates please
bruv chariots rule
ross2009
non as yet mate should get my gearbox adaptor tomoz as its at the delivery depot
then I can get the whole lot in and start making engine mounts and gearbox mounts
ross2009
woohoo adaptor turned up today can't wait to bolt it all up
ross2009
so I got the adaptor the other day had some spare time tonight to see what it looks like on and the results are in
now I can get the whole lot in and start mocking up engine mounts and gearbox mounts
retroboyo
Never seen a bell housing adapter look that good before
ross2009
custom made my friend lol
glenn
coming along nicely there ross
ross2009
slowly but surely glenn lol
Looking good.
What gearbox are you using?
gooseygander110
love this thread........ very inspiring !!
ross2009
thanks guys its a r154 5 speed from the mk3 Toyota supraSpeedtouch wrote:Looking good.What gearbox are you using?
ment to be pretty bomb proof with a couple of mods
I went thro all that a couple of pages ago lol
manse73
I like shiney bits lol
bruv chariots rule
ross2009
lol be more coming soon got lots of stuff coming from the states kev so keep an eye out
manse73
I am watching and waitingross2009 wrote:lol be more coming soon got lots of stuff coming from the states kev so keep an eye out
bruv chariots rule
ross2009
a whole box of goodies turned up today most of my arp bolts for the engine sump bolts, timing cover bolts ,engine mount bolts , exhaust header bolts crank pulley bolt oil pump drive shaft I know I already have one but as being arp much stronger and a stud kit for the oil pump
manse73
Lots of shiney bits
bruv chariots rule
ross2009
im gonna get the thing in this weekend and get some engine mounts and stuff made
hopefully
then i can crack on with getting the motor built
hopefully
ross2009
done a bit today trial fitted the whole lot
and soon ran into a problem with the sump on the distance from the bulk head to the crossmember, it's just to narrow to get the whole thing in and flat
so with a little modification with a grinder I sectioned the crossmember
which will be all reinforced after I'm done but finally she's in and sort of flat
took a couple of pics with the manifold and rad in
shifter sits near on perfect too
there is one problem the reverse switch on the side of the gearbox is touching the side of the tunnel
so that will have to be modified to get the shifter sitting in the center
but apart from the bad bits it's still progress I was meant to start making the engine mounts today but never got around to it so as soon and the sump and starter etc is all on and the motor is in the right place I can start making them
ross2009
so been doing a little bit most nights after work before it gets dark but only get a couple of hours this is what I've been up to
I've started to reinforce the subframe I cut a chunk out of the plate I've used is 8mm thick so that ain't going no where
not the prettiest I must admit but does the job was debating or not wether to put a piece on the back aswell just to make sure that way it will tie each surface together and shouldn't move what so ever I planned in getting the engine bk in for mocking up the engine mounts etc tonight but was getting dark and when I had the engine above the slam panel the straps decided to come lose so now I have a nice bent up slam panel
o well another job to do
Looking good.
ross2009
thanks man
there you go new sub frame sort of lol
just gotta get the top mounts for the rack sorted now but I'd like to get the engine in place first so I know I have room shouldn't be a problem but I'd hate to do it and it be wrong
glenn
good work ross
glenn
good work ross
ross2009
cheers glenn gotta do some more modifying tomoz as the front of the sump just slightly sits on the front lip of the cross member so gonna have to cut out about 10-15 mm of the front to let the front of the engine sit down a little
as its pointing up at the mo then i can get all my angles and hights right for the mounts and gearbox
