The Most Infamously Common E30 Fault
Barx325i
Sat Sep 19, 2009 10:20 pm
psychochild187 wrote:rear axel bushes
that's a winner, has that been mentioned yet or did it slip the net?
TurboTurner
Sun Sep 20, 2009 12:25 pm
another vote 4 central lockin when i brought it had all 3 door motors on my cab broken and the pin that connects the wire on the door to the car was corroded lol
also had a oil leak coming from a rubber seal near the oil filter
now fixed that looks like the head might be leaking oil but i love the car! :D
wouldnt be a clasic if i wernt under the bonnet! :D
TonyWilson
Sun Sep 20, 2009 4:05 pm
It's all a love hate relationship
richardlkay
Sun Sep 20, 2009 4:09 pm
so there's not much to look out for then 8O :mad: :D
Rick
_______________________________________
E30 (91) 318iS - Alpine White II|14" BBS Cross Spokes|Cloth Sports seats
B7 (07) Audi A4 2.0 TD
e30_singh
Sun Sep 20, 2009 4:21 pm
Rust is probably the biggest factor, stopping me buying another E30 again.
They rust everywhere, windscreen, jacking point, sunroof, window seals, arches!
blackcountrybimmerman
Tue Sep 22, 2009 12:14 am
frogman wrote:
Alex wrote:Hydrolic Headlight adjusters never work
You got there before me Alex!
Has anyone here actually got a working system?
Mine works fine...
It doesn't look like it does in my sig pic anymore
6potpower
Tue Sep 22, 2009 1:42 am
e30_singh wrote:Rust is probably the biggest factor, stopping me buying another E30 again.
Mine has no rust and it never has
Felix79
All loved up !
Tue Sep 22, 2009 11:29 am
Speedo dieing
SI board going due to leaking battery.
Felix79 aka Dan
E85 Z4M Roadster
HairyScreech
Tue Sep 22, 2009 11:44 am
thing is i bet most people havent noticed that there gone on there car, i bet buggered bushes are 10x more common than we would believe.
leeparkes
Wed Sep 23, 2009 12:34 am
All of the above plus
Bonnet strut!
I once had one of the rollers on the bonnet slam on the middle of my back on a windy day.
pain is not the word!
Cypriotgeeza
Wed Sep 23, 2009 2:59 pm
leeparkes wrote:All of the above plus
Bonnet strut!
+2!! Its happened to me with mine AND my dad with his baur! haha
Check my M30 build threads:
Fushion_Julz
Wed Sep 23, 2009 4:48 pm
I would say number 1 issue is the headlight adjusters...Never seen a working set....and I had a 320i company car back in 1990 and they didn't work on that, even!
The upholstery, especially the drivers' seat (base and bolsters) would be a close second...and it isn't just cloth that's a problem, leather is equally as prone to wear!
The comfort seats are marginally better, and they don't have the spring collapsing issues of the sports seats...
Front/rear fuel lines rusting, central locking relays swimming in water, sunroof panels and trays rusting out, rear arch rust, front wing lower edge rust, leaky rear light and boot seals, touring tailgate rust, touring sagging headlining, noisy or seized heater motors and leaky heater valves are all other common issues...
Things like bushes, though, are service items, really...all cars have those sort of problems if they aren't looked after.
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Morat
Wed Sep 23, 2009 4:54 pm
Knackered RSBs do make you feel like a drift hero - until you realise that you're only doing 20mph :)
toby
Wed Sep 23, 2009 4:56 pm
The Most Infamously Common E30 Fault - post whoring?
Nay
Channel Island Crew
Channel Island Crew
Wed Sep 23, 2009 5:51 pm
Rust
Water in footwells.
Sqeaky, whinning steering.
Central locking
Buying an E30?? :chuckle:
Uni is killing the project.
KimH
Fri Sep 10, 2010 9:48 pm
From reading many posts here, and elsewhere, virtually anything under the bonnet functioning less than 100% results the ubiquitous Kangaroo petrol that seems to find its way into most E30s. I’ve heard of people fixing it with any ”“ some ”“ or all of the following: fuel pump; fuel filters; injectors; rubber hoses; inlet manifold gaskets; distributor caps; rotor arms; Spark plugs; HT Leads; TPSs; FPRs; AFMs; ECUs; electrical connectors, and in my case, the blue temp sensor.
Fri Sep 10, 2010 9:53 pm
Well these are over 20 yrs old, so some of it will need replacing
TouringTash
Fri Sep 10, 2010 9:54 pm
owners not using E30 wiki.
318i Touring
octanejunkie
Fri Sep 10, 2010 11:11 pm
As Hairy said, i bet bushes have to the most common failed component. Many E30's will have shagged out bushes, but people may not know as the symptoms are not that obvious.
Generally though, the faults (rust issues aside) are nearly all electrical. Only interior items come second.
Many electrical faults can be eradicated by spending an afternoon cleaning up connections.
RUST is the number one fault though. Who hasn't had to deal with it in some form or another on their E30??? :wink:
Fri Sep 10, 2010 11:23 pm
You've all overlooked the most crucial item - the infamous glovebox torch, being either missing, not working, or having dropped down behind the centre console.
I have four of them, in various states of disorder. winkeye
godinman
Fri Sep 10, 2010 11:29 pm
Not posted about much, but in my experience it's a rare E30 that has an intact brake fluid tank/pot/thing lid.
alan1272
Sat Sep 11, 2010 1:16 am
how about corroded rear brake lines? never had an E30 where they didn't need replacing and what a git of a job they are! :cry:
svenga
Sat Sep 11, 2010 2:51 am
My e30 hydro headlight adjustment works spot on, is this a browny point?
However i have the common temprimental fuel gauge, brake wear indicater flicking on & off, rear arch surface rust.
And an overtightened clutch fluid pot which cracked the lid letting water & condensation inside meaning i get a sloppy clutch occasionally!
trevski
Sat Sep 11, 2010 8:20 am
Can't believe no one has mentioned the famous cracking head on the m20 due to it being made from cadburys dairy milk 8O
Barx325i
Sat Sep 11, 2010 8:28 am
not sure that raised any concern in the 316..
zaust
Zone day release
Sat Sep 11, 2010 8:37 am
Been reading all of this and my conclusion is....
The most common E30 fault is the "Nut behind the wheel".
M30 Tech 1 Touring on gas.
beemerbird
Sat Sep 11, 2010 8:49 am
To be honest, I think the most common E30 fault is 'owner delusion' which arises when people buy a relatively cheap car, only to find it sucks every spare ounce of time and money from said owner!
Dezzy
CR24v it's a lifestyle
Sat Sep 11, 2010 9:18 am
Go and buy any 1990 car and hope to spend no time and money on it. See how far you get. :D
**BANNED**
Sat Sep 11, 2010 12:50 pm
bss325i wrote:
beemerbird wrote:
skipunda wrote:ABS light stuck on due to a relay
Good call.
Thats a prefacelift thing i'm sure.
My '88 touring has the early system,and I am sure that early 'Bracknell Specials' in facelift form will do to....
Youth is wasted on the young.
Sat Sep 11, 2010 11:15 pm
zaust wrote:Been reading all of this and my conclusion is....
The most common E30 fault is the "tight C Nut behind the wheel".
I corrected it for ya :D
Dezzy
Sat Sep 11, 2010 11:17 pm
Problem now is driftcockers want to ruin them!
e30den
Sat Sep 11, 2010 11:35 pm
basky wrote:water temp gauge :?:
A heavy handed tap on the dash sorts mine out.
lumpy idle i can live with.
shimsheemer
Sun Sep 12, 2010 12:34 am
Just one?!?
My vote would have to be the wobbly fuel gauge that causes the handbrake button to disappear thus allowing water into the boot which in turn causes a lumpy idle from time to time which, of course, causes the ABS light to come on which naturally adds a little more rust here and there forcing the intensive headlight wash system to jam...
LagunaE30
Mon Sep 13, 2010 11:41 pm
cracked dash? chattering gearboxes? leaky convertible roofs? just some of the things i've come across in my time
e30_mtec
Tue Sep 14, 2010 12:00 am
noisy diff??? every e30 has that issue
