cosworth conversion
chip-3door
I believe you can get decent power out of any engine with enough time and money spent on it, my issue with the M20 isnt that you cant do so, its that the damn thing has so much weight, and especially of benefit with a 4 cylinder swap is that its the front two cylinder that you lose, moving the centre of gravity backwards, to me thats a great idea, and BMW would seem to agree as thats what they did with the E30 M3 anyway!
chip-3door
PS
I talk to martin hadland from time to time, will try and remember to ask him a bit about the specifics of the E36 cossie at some point, annoyingly i was actually sat with him yesterday chatting away and completely forgot about the subject of BMW's at the time, doh!
fuzzy
i can help you with specific problems on the e30, although i didnt carry out the work myself i was kept informed all the way, and i only got mine back 2 months ago
.and the mechanic did moan a lot about various problems.
chip-3door
what box does yours use, the beemer one or a cossie T5?
chip-3door
just read your siganture which says what box!
same way i would do it
standard box for the engine + custom prop
as opposed to custom bellhousing for the box and a standard prop
fuzzy
hi mate, ive just finished playing around and if you go to
http://uk.msnusers.com/fuzzysbmwcosworth
then you should find some photos.let me know if it works as ive said before im a learner with the pc and i dont really know what im doing
if that isnt working for you i have a couple of photos in the photo gallery section
chip-3door
SR20DET had cast pistons and rods, so it cant (in standard form) handle either lots of rpm or lots of boost.weegaz22 wrote:personally if it was me i would use an sr20det engine and box, cheaper to buy than the cossie and probably just as cheap to tune(Ԛ£1000 quid will get you around 280bhp), chain driven cams as well so nice and strong
Very expensive engine to get decent power from, on a cossie you can get 380 on a totally standard engine with just a change of chip/injectors/turbo, you wont get anywhere near that on a SR20DET without spending a lot of money.
i did say personally cos i wouldnt be trying to tune the tits off it, theres guys on the sxoc with over 350bhp s14s still running stock cast pistonschip-3door wrote:SR20DET had cast pistons and rods, so it cant (in standard form) handle either lots of rpm or lots of boost.weegaz22 wrote:personally if it was me i would use an sr20det engine and box, cheaper to buy than the cossie and probably just as cheap to tune(Ԛ£1000 quid will get you around 280bhp), chain driven cams as well so nice and strong
id be happy with the 280-300bhp, still plenty reliable
