These plates are back in stock BTW, £50 posted per set to zoners
Rear camber adjustment plates
You can buy bushes that raise the beam by 12mm which is about the max without molesting the floor/chassis rails/diff mounts/trans tunnel etc etc
Rallyprep_UK
- formerly Driftnething
I also used snap on carbide grinding bits on an air powered ddie grinder. Whizzed through it in minutes
deadbeat30
Do u have any more of these available?
maxfield
He had some around Xmas time so I'm assuming he's still got some - drop him a PM I'm sure hell be happy to help
Driftben
Have you got an more of these sets available dan?
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
Yep, exchange beams also available
Driftben
whats the prices for just the plates and a price for the exchange beams dan?
6pot wilwoods front
4pot Porsche rear
£50 inc post for plates
£160 + post for exchange beam sandblasted and powdercoated
ungovernable
are plates and beam exchange still available mate?
prices still the same?
thanks rich.
thanks rich.
Yes still doing these, price is now £200 and there is a longer wait unfortunately, I dont have any ready done because im so busy with other work, but if you send me your beam I can have it done in about 2 weeks normally
ungovernable
do you do diff mount point reinforcement as well?
thanks rich.
thanks rich.
Not usually but I can if you want me to, ive never had problems with the diff mounts on the subframe, very unusual for them to break
ungovernable
ive got an rb25det dropped in her so just over 300 bhp, been told its advisable with higher power engines.
just trying to source a reasonably priced subframe so mine isnt sat for few weeks.
thanks rich.
thanks rich.
ungovernable
thanks rich.
thanks rich.
ungovernable
thanks rich.
thanks rich.
If you just want some 4mm plate welding over the mounting points its not much of an issue, personally I would double hang the diff using an E36 back plate, will be much stronger than a bit of plate on the beam
Some good pics in here - http://www.e30zone.net/modules.php?name ... estoration
ungovernable
was going to do both for extra insurance.
thanks for your advice.
where do i have the beam sent to please.
cheers rich.
cheers rich.
ungovernable
have got a rear beam on its way to you at the address on your facebook page, WS11 7LH
hope thats right.
cheers Rich
hope thats right.
cheers Rich
